Thanks a lot for all work !
I’ll give try as soon as possible.
Yes !!! Messages appear with TermPro.
I can go a little far away
Many thanks !!!
You are welcome.
But it’s not much fun to use the Serial Port Protocol over e.g. teraterm.
You are better off, if you use the RFComm Connection on the PC side e.g. with the 32feet.net library which is used in my PC/Bluetooth file Transfer Project in Codeshare.
(If you have a 64 bit Windows Version you must open VS as administrator to run the PC-Client on the PC side). You can extract all you need from this FEZ/PC Bluetooth File Transfer Project.
Things goes fun: communication with Spider with Bluetooth module in Serial Port Protocol works with WP8 and Windows Store App on 8.1.
I have discovered that my Bluetooth usb dongle on my desktop won’t work for SPP :’( It is a very cheap one, I think I must buy another (and not bluesoleil !!!).
Now I would try with Windows 7 and 32feet.
When all is working, I’ll post my code here !
Thanks again to RoSchmi and Vb-daniel for help and time !
Thanks for your feedback, looking forward to see your code.
I am in joyful anticipation to see the code
