Hello everyone,
I’m not sure if that’s still OK for general discussion or if it should go into off-topic…
Either way I just wanted to give a tip for smt (de)soldering… I got the ChipQuick delux package (see picture attached) from digi-key a while ago (http://tinyurl.com/7p8wh9g) and I absolutely love it.
You can find some videos about it on youtube… even Sparkfun made a video for it as they carry the starter kit http://www.sparkfun.com/products/10925…
It came in extremely handy for my Cerb40 as I found the regulator and cap on some other hardware and with my regular soldering iron I was able to lift them off within few minutes. Had I used my heat gun it would have taken at least as long and I’d have to apply a lot more heat that might risk destroying the components.
I sometimes even use it for through-hole stuff, especially when I want to replace multi-pin headers or some ICs that are directly soldered onto the board.
I don’t get anything from this suggestion but I really love using that stuff so I wanted to share it with you. Enjoy your SMT components…
