SMS Gateway Help
I’m trying to send a text message (SMS) with a CANxtra. I use the sms gateway provided by my telephone company: [url]https://www.bibob.dk/SmsSender.asmx[/url].
I am trying to modify this Powershell script: [url]http://www.xipher.dk/WordPress/?p=616[/url].
The only thing I have changed is that I have added the “deliveryReport”, as I thought it might be needed. See this link:
[url]https://www.bibob.dk/SmsSender.asmx?op=SendMessage[/url], I have also changed the server to https://www.bibob.dk/ instead of https://www.bibob.dk/SmsSender.asmx, as the host header is read only.
Here is my code (I have replaced my username and password with x’s):
using System.IO;
using System.Net;
using System.Text;
namespace SMSSender
    class SMS
        public void SendSMS(int number, string message)
            if (number.ToString().Length != 8)
                Debug.Print("Number has to be 8 digits");
                return;
            string username = "xxxxxxxx";//My phonenumber
            string password = "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx";//Converted to MD5 Hash
            string server = "https://www.bibob.dk/";
            string XMLString = "<?xml version=\"1.0\" encoding=\"utf-8\"?>";
            XMLString += "<soap:Envelope xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\"";
            XMLString += "xmlns:xsd=\"http://www.w3.org/2001/XMLSchema\"";
            XMLString += "xmlns:soap=\"http://schemas.xmlsoap.org/soap/envelope/\">";
            XMLString += "<soap:Body><SendMessage xmlns=\"http://www.bibob.dk/\">";
            XMLString += "<cellphone>"+ username + "</cellphone>";
            XMLString += "<password>" + password + "</password>";
            XMLString += "<smsTo><string>" + number.ToString() +"</string></smsTo>";
            XMLString += "<smscontents>" + message + "</smscontents>";
            XMLString += "<fromNumber>" + username + "</fromNumber>";
            XMLString += "<deliveryReport>" + false + "</deliveryReport>";
            XMLString += "</SendMessage></soap:Body></soap:Envelope>";
            Byte[] bytesToSend = Encoding.UTF8.GetBytes(XMLString);
            HttpWebRequest myWebRequest = (HttpWebRequest)WebRequest.Create(server) as HttpWebRequest;
            myWebRequest.Method = "POST";
            myWebRequest.Headers.Add("Man", "POST /SmsSender.asmx HTTP/1.1");
            myWebRequest.ContentType = "text/xml; charset=utf-8";
            myWebRequest.ContentLength = bytesToSend.Length;
            myWebRequest.Headers.Add("SOAPAction", "http://www.bibob.dk/SendMessage");
            using(Stream outputStream = myWebRequest.GetRequestStream())
                outputStream.Write(bytesToSend, 0, bytesToSend.Length);
Bassicly I got two questions:
At this link: [url]https://www.bibob.dk/SmsSender.asmx?op=SendMessage[/url] under SOAP 1.1 it says that the first header must be:
He does it this way in the Powershell script:
$objHTTP.setRequestHeader(‘Man’, ‘POST’ + ’ ’ + $SoapServer + ’ HTTP/1.1’)
Is it correct just to do in C#?
myWebRequest.Headers.Add(“Man”, “POST /SmsSender.asmx HTTP/1.1”);
Is it correct to use a HttpWebRequest? I though about using sockets, and then just send the data, but then I can not set the headers, needed for it to work.
Btw if I run the code, if throws an exception when trying to get the request stream:
This is the debug output:
 #### Exception System.Net.Sockets.SocketException - CLR_E_FAIL (1) ####
    #### Message:
    #### Microsoft.SPOT.Net.SocketNative::getaddrinfo [IP: 0000] ####
    #### System.Net.Dns::GetHostEntry [IP: 0008] ####
    #### System.Net.HttpWebRequest::EstablishConnection [IP: 00e1] ####
    #### System.Net.HttpWebRequest::SubmitRequest [IP: 0013] ####
    #### System.Net.HttpWebRequest::GetRequestStream [IP: 0008] ####
    #### SMSSender.SMS::SendSMS [IP: 0112] ####
    #### CANxtra_Webserver_LCD.Program::Main [IP: 006a] ####
    #### SocketException ErrorCode = -1
A first chance exception of type 'System.Net.Sockets.SocketException' occurred in Microsoft.SPOT.Net.dll
    #### Exception System.Net.WebException - 0x00000000 (1) ####
    #### Message: host not available
    #### System.Net.HttpWebRequest::EstablishConnection [IP: 00f1] ####
A first chance exception of type 'System.Net.WebException' occurred in System.Http.dll
An unhandled exception of type 'System.Net.WebException' occurred in System.Http.dll
Additional information: host not available
I do not have much experience with XML, so any help would be much appreciated :slight_smile:
[quote]Is it correct just to do in C#?
myWebRequest.Headers.Add(“Man”, “POST /SmsSender.asmx HTTP/1.1”); [/quote]
Wrong. You don’t need to do that at all. HttpWebRequest object will do it for you based on Method property.
Okay I tried to uncomment the part after:
myWebRequest.Method = “POST”;
But then throws an exception, that you have to set the contentlength. So I did, the same way as I did before:
But it still not working. I have tried changing server to https://www.bibob.dk/SmsSender.asmx as well, but that it still throws an exception the same place. Outputting: “Additional information: host not available” :frowning:
Look at the link:
It shows what the post message should look like:
Host: www.bibob.dk
Content-Type: text/xml; charset=utf-8
Content-Length: length
SOAPAction: "http://www.bibob.dk/SendMessage"
<?xml version="1.0" encoding="utf-8"?>
<soap:Envelope xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/">
  <soap:Body>
    <SendMessage xmlns="http://www.bibob.dk/">
      <cellphone>string</cellphone>
      <password>string</password>
      <smsTo>
        <string>string</string>
      </smsTo>
      <smscontents>string</smscontents>
      <fromNumber>string</fromNumber>
      <deliveryReport>boolean</deliveryReport>
    </SendMessage>
  </soap:Body>
</soap:Envelope>
Okay. I changed my code to this:
                return;
            //string server = "https://www.bibob.dk/SmsSender.asmx";
            string XMLString = "POST /SmsSender.asmx HTTP/1.1";
            XMLString += "Host: www.bibob.dk";
            XMLString += "Content-Type: text/xml; charset=utf-8";
            XMLString += "Content-Length: " + message.Length;
            XMLString += "SOAPAction: \"http://www.bibob.dk/SendMessage\"";
            XMLString += "<?xml version=\"1.0\" encoding=\"utf-8\"?>";
            Debug.Print("Send SMS");
            Debug.Print("Message has been sent");
But it still not working…
This is your content:
  <soap:Body>
      <smsTo>
      </smsTo>
    </SendMessage>
  </soap:Body>
</soap:Envelope>
Method ,Content type and content length you set through properties:
Host and SOAPAction you add to the Headers dictionary:
myWebRequest.Headers.Add("Host", "www.bibob.dk");
I have tried that, and it does not work.
And you can not set the host header, as it will print this exception:
“Additional information: Cannot update restricted header: Host”
See this page for more information: [url]Microsoft Learn: Build skills that open doors in your career .
Ok I guess host is automatic then. Leave it out and try.
Already done that, and it’s not working :frowning:
Set your server variable to:
If it doesn’t work then use
https://www.bibob.dk/SmsSender.asmx/SendMessage
I have also done that. I was actually hoping I was doing something totally wrong, because I have tried to adjust so many of the variables :frowning:
Ok, can you post your final version here
Of couse. I have left all as it was, so you can see all the things i tried:
using System.IO;
using System.Net;
using System.Text;
namespace SMSSender
    class SMS
                return;
            //string server = "https://www.bibob.dk/";
            //string server = "https://www.bibob.dk/SmsSender.asmx/SendMessage";
            /*string XMLString = "POST /SmsSender.asmx HTTP/1.1";
            XMLString += "SOAPAction: \"http://www.bibob.dk/SendMessage\"";*/
            //myWebRequest.Headers.Add("Host", "www.bibob.dk");
            using(Stream outputStream = myWebRequest.GetRequestStream())//THis is where it throws an exception
Ok, final suggestion. Try to make it work in regular .Net app on your PC first. Also get the response and see what error is returned there if anything.
Okay, I will try that and then post my progress :slight_smile:
Thank you for your help so far!!!
I found this page ([url]http://translate.google.com/translate?sl=da&tl=en&js=n&prev=_t&hl=en&ie=UTF-8&layout=2&eotf=1&u=http%3A%2F%2Fphpgeek.dk%2Fblog%2F2008%2F03%2F01%2Fen-billig-sms-gateway-l%25C3%25B8sning-ja-det-er-muligt%2F&act=url[/url] - translated to english) by a user who made a php-script.
I only had to modify it a bit to get it working (it was a bit outdated). This is the final code:
<?php
 * BiBoB SMS Gateway Class
 * Class using the BiBoB Webservice to send out SMS messages.
 * Furthermore there is a few of utilities functions that can be used too.
 * If you have any questions - feel free to contact me.
 * Developed by:
 * Johan Holst Nielsen
 * johan@ phpgeek.dk
 * www.phpgeek.dk
 * Use it as you want - and distribute is as you want - but please leve this message.
 * Read more about BiBoB at www.bibob.dk
 * EXAMPLES
 * Send out an SMS:
 * <?php
 * $sms = new BiBoB_SMS('YourBiBoBNumber','YourBiBoBPassword');
 * if($sms->Login()===true) {
 *   $result = $sms->SendMessage('YourFriendsNumber','A nice and friendly message');
 *      if($result === true) {
 *         echo 'Message is sent';
 * Get your account Balance:
 * <?php
 *   $balance = $sms->GetBalance();
 *   echo 'I got '.sprintf('%.2f',$balance).' DKK left on my account';
 * Please read the comments in the source for more information.
class BiBoB_SMS {
     * Defines where the SOAP Client can find the BiBoB SMS WSDL
     * @ var string
    private $wsdl = 'https://www.bibob.dk/SmsSender.asmx?WSDL';
     * Variable for the cellphone number. If you set your cellphone number here - you
     * do not need to add it when initialize the class.
     * @ var string
    protected $cellphone = '';
     * Varibale for the password in plain text. If you set your password here - you
     * @ var string
    protected $password = '';
     * Contructs the class - and adds cellphone number and password
     * Set the cellphone number and password.
     * @ param string $cellphone
     * @ param string $password
    public function __construct($cellphone='',$password='') {
        if(!empty($cellphone)) { $this->cellphone = $cellphone; }
        if(!empty($password)) {  $this->password = md5($password); }
     * Performs a login
     * Function is not needed to do anything. But use it to be sure you
     * got the right username and password when using other functions.
     * Returns true on successfull login - returns the error message on false.
     * @ return boolean/string    Returns the error message on failure - otherwise boolean true.
    public function Login() {
        $param = array();
        $param['cellphone'] = $this->cellphone;
        $param['password'] = $this->password;
        $result = $this->doSOAPCall('Login',$param);
        if($result->LoginResult === '') {
            return true;
        return $result->LoginResult;
     * Get your balanace
     * Get your current balance from BiBoB. The amount is returned as a float
     * in Danish Kroner.
     * @ return float    The amount on your account balance.
    public function GetBalance() {
        $param = array();
        $result = $this->doSOAPCall('GetBalance',$param);
        if($result->GetBalanceResult===NULL) {
            return false;
        return $result->GetBalanceResult;
    * Get your contact list
    * Get the contact list from your WebSMS at bibob.dk
    * Returns an array with the contacts. Each got the keys
    * 'firstname', 'lastname' and 'cellphone'
    * Set parameter utf8decode to true if you want the text
    * to be encoded in ISO-8859-1
    * Returns false on failure.
    * @ param    boolean    $utf8decode    Default set to true
    * @ return    array
    public function GetContacts($utf8decode=false) {
        $param = array();
        $result = $this->doSOAPCall('GetContacts',$param);
        if($result->GetContactsResult===NULL) {
            return false;
        $contacts = array();
        foreach($result->GetContactsResult->string as $r) {
            if($utf8decode) { $r = utf8_decode($r); }
            $rx = explode(':',$r);
            $contacts[] = array('firstname'=>$rx[0],'lastname'=>$rx[1],'cellphone'=>$rx[2]);
        return $contacts;
     * Send a SMS message
     * Send one - or more SMS messages through the WSDL. Content needs to be string
     * the string will automatic be UTF-8 encoded. Just leave date empty - otherwise
     * you want to send a scheduled message.
     * The to parameter can be a string of one cellphone numer - or can be an
     * array of 2 or more numbers. If it is an array and identical message will be
     * sent to all numbers.
     * Returns true on success and false on failure.
     * @ param    string/array    $to
     * @ param    string            $content
     * @ param    dateTime        $date
     * @ return    boolean            True on success, False on failure
    public function SendMessage($to,$content='',$date='') {
        if(trim($content) == '') { return false; } //We need some content in the SMS
        $param = array();
        if(is_array($to)) {
            foreach($to as $number) {
                $param['smsTo']['string'][] = $number;
        else {
            $param['smsTo'] = array('string'=>$to);
        $param['smscontents'] = $content;
   		$param['deliveryReport'] = false;
        $result = $this->doSOAPCall('SendMessage',$param);
        if($result===NULL) {
            return false;
        return true;
     * Do a SOAP call
     * Do a SOAP call to the the given WSDL. Returns the result.
     * @ param    string    $method    The method that have to be called
     * @ param    array    $param    Parameters given as a array
     * @ return    array    Array of the result
     * @ access    private
    private function doSOAPCall($method,$param=array()) {
        $soapClient = new soapClient($this->wsdl);
        $result = $soapClient->__soapCall($method,array('parameters'=>$param));
        return $result;
I will try to base my code on that instead :slight_smile:
I only need to do something like you did:
[url]http://wiki.tinyclr.com/index.php?title=Cdyne_SMS_Web_Service[/url]
And change “requestUrlString” to “https://www.bibob.dk/SmsSender.asmx?WSDL” and add the different parameters.
Note that we found the HttpWebRequest very slow… using a direct socket to port 80 and writing a string worked much better.
Of course if you’re not doing many, then the simplicity of the HttpWebRequest is much better.
Okay. Thank you.
I might try it out in the future :slight_smile:
