i’m in the process of building a kind of home automation system.
I want to be able to catch the status changes of the buttons on the wall.
I would like to use “triggers” and Digital Input events and to not “poll” under the hood the buttons.
My idea is to use an Y socket and have all the input port 4 to 9 in NAND feeding the pin 3 used as trigger using an 74HC30.
The input of the 74HC30 will be pulled up to 1 and there will be a button to ground.
The same button will set to ground one of the pin from 4 to 9… so in total 6 button per Y socket.
In this case on the pin 3 status change event i will read all the other pin status.
Since they will be connected to a physical button, do you think there will be the time to read the correct value???
http://www.kapipal.com/netmicrodomotic
