I needed to display some basic debug messages on the T35 Display without worrying about the position of the text or create a complicated ui, so I created a simple DebugLCD class. It displays about 20 lines and then scrolls up when next text is added after that. Don’t know if there is already a simple way to do it, but it works for me
using Microsoft.SPOT.Touch;
using Gadgeteer.Networking;
using GT = Gadgeteer;
namespace DebugLCDTest
class DebugLCD
private Display_T35 lcd = null;
private Bitmap buffer = null;
private string[] log = new string[22];
private int counter = 0;
private const int startX = 15;
private const int startY = 10;
public DebugLCD(Display_T35 LCD)
lcd = LCD;
buffer = new Bitmap( (int)LCD.Width, (int)LCD.Height);
// clear lcd
lcd.SimpleGraphics.Clear();
private void drawBuffer()
lcd.SimpleGraphics.DisplayImage(buffer, 0, 0);
private void scrollLog()
for (int c = 0; c < counter - 1; c++)
log[c] = log[c + 1];
counter--;
public void Print(string msg)
log[counter++] = msg;
if (counter > 21)
scrollLog();
buffer.Clear();
// draw frame
buffer.DrawRectangle(Color.White, 1, 5, 5, (int)(lcd.Width - 10), (int)(lcd.Height - 10), 5, 5, Color.White, 0, 0, Color.White, 0, 0, 125);
// to buffer
for (int c = 0; c < counter; c++)
buffer.DrawText(log[c], Resources.GetFont(Resources.FontResources.small), Color.White, startX, startY + (c * 10));
drawBuffer();
Example Program:
public partial class Program
private DebugLCD debugLCD = null;
debugLCD = new DebugLCD(display);
button.ButtonReleased += new Button.ButtonEventHandler(button_ButtonReleased);
debugLCD.Print("Program Started");
void button_ButtonReleased(Button sender, Button.ButtonState state)
debugLCD.Print("Button Pressed - " + counter.ToString());
counter++;
