I have some a .net standard library project, with very basic .net code.
Ithis library is used in “standard” full framework & Xamarin (iOS/Android) project, I would like to reuse it also in a FEZ/TinyCLR project.
Is it possible?
Thank you.
Yea just copy the code into the project, and fix the compile errors.
If you want to compile the same code in many different project flavors, see : https://old.ghielectronics.com/community/forum/topic?id=20173
That’s a post in the ‘old’ GHI forum. The same post in this newer forum has some formatting problems that make it hard to make sense of, but can be found here: Using Shared Projects with NETMF
