SerialPort.Read truncates received data
Hi everybody. I am having problems reading serial data that includes 0x02 and 0x03 ‘characteres’ (STX and ETX).
SerialPort.Read truncates the data at the 0x02 position and I only get the data before the 0x02. I verified that using a Y serial cable connected to my G80 COM3 and to Hyperterminal in parallel. Hyperterm shows all the data, but SerialRead stops reading when it finds a 0x02. If I check for data using SerialPort.BytesToRead after that, it says there is no further data to read.
This is the code:
public static SerialPort COM3 = new SerialPort("COM3");
public static void COM3_init() {
	COM3.BaudRate=2400;
	COM3.ReadTimeout = 0;
	COM3.Handshake = Handshake.None;
	COM3.Open();
public static void Thread_Read_COM3() {
	while(true) {
		if (COM3.BytesToRead > 0)
			Thread.Sleep(my_wait);	// I've tried even with my_wait=3000 to give it time
			msg3len = COM3.BytesToRead;
			COM3.Read(bCOM3rcv, 0, COM3.BytesToRead);
			// At this point I get only the bytes BEFORE the 0x02
			// I added this to check again in case the rest of the data is available after reading the first part
			if (COM3.BytesToRead > 0) {
				// I check for more bytes to read, but there are no more.
		Thread.Sleep(100);
Thanks a lot for your help.
JCP
i belive this code could help you
https://www.ghielectronics.com/docs/15/uart-serial
i am also using TinyCLR ports 0.5.0 and have no problem with handle of this two bytes with [RDM6300 RFID CODE] (https://github.com/valoni/TinyCLR_Drivers/tree/master/TinyCLR%20Os%20Examples/RDM6300/)
Thanks a lot for sharing your code and . There must be something I’m doing wrong. I’ll look at your code and try to figure out where my mistakes are.
Have a look at this code. It is running quite happily in many installations of our system in EU hospitals environments.
using System.IO.Ports;
namespace PPlusApplicatorID
internal class InterfaceIO
private readonly SerialPort port;
private readonly byte[] inBuffer = new byte[32];
private readonly byte[] outBuffer = new byte[32];
private readonly Globals g;
private int i;
private int inByte;
    private int waitLoop = 100;
    private const byte Enq = 0x05;
    private const byte Stx = 0x02;
    private const byte Etx = 0x03;
    public enum Commands : byte
        GetStatus = 0,
        ClearStatusCodes
    public InterfaceIO(Globals value)
        this.g = value;
        // Instance IO and open the port
        this.port = new SerialPort("COM1");
        this.port.BaudRate = 9600;
        this.port.Parity = Parity.None;
        this.port.DataBits = 8;
        this.port.StopBits = StopBits.One;
        this.port.Handshake = Handshake.None;
        this.port.ReadTimeout = Timeout.Infinite;
        this.port.Open();
        // Clear the buffers down
        this.ClearBytes(inBuffer);
        this.ClearBytes(outBuffer);
    public void ClearBytes(byte[] bytes)
        for (i = 0; i < bytes.Length; i++)		    // Clear the byte block
            bytes[i] = 0;
    public void PerformIo()
            this.port.DiscardInBuffer();
            inByte = this.port.ReadByte();
            g.Led.Flash();
            switch (inByte)
                case Enq:   // Get current status
                    // Command
                    this.outBuffer[0] = (byte)Commands.GetStatus;
                    // Temperature
                    this.outBuffer[1] = (byte)(this.g.Temperature & 0xFF);
                    // Applicator 1
                    this.outBuffer[2] = (byte)(this.g.Applicator1 & 0xFF);
                    // Applicator 2
                    this.outBuffer[3] = (byte)(this.g.Applicator2 & 0xFF);
                    // Filter
                    this.outBuffer[4] = (byte)(this.g.Filter & 0xFF);
                    // Status
                    this.outBuffer[5] = (byte)(this.g.Status);
                    // Versions
                    this.outBuffer[6] = this.g.VerMajor;
                    this.outBuffer[7] = this.g.VerMinor;
                    // CRC8
                    this.outBuffer[8] = this.g.Crc8.DoCrc8(this.outBuffer, 8);
                    this.port.WriteByte(Stx);
                    this.port.Write(this.outBuffer, 0, 9);
                    this.port.WriteByte(Etx);
                    break;
                case Stx:   // Start a command
                    this.port.Read(this.inBuffer, 0, 1);
                    this.ProcessCommand(inBuffer[0]);
                    break;
                default:    // Ignore all else
                    break;
            Thread.Sleep(10);
    private void ProcessCommand(byte p)
        waitLoop = 100; // 100 * 10ms = 1 second
        switch (p)
            case (byte)Commands.ClearStatusCodes:
                while (this.port.BytesToRead < 3 && --waitLoop > 0)
                    Thread.Sleep(10);
                if (waitLoop > 0)
                    try
                        this.port.Read(this.inBuffer, 1, 3);
                        if (this.g.Crc8.CrcCheck(this.inBuffer, 2) && (this.inBuffer[3] == Etx))    // Command was well formed
                            this.g.Status = ErrorFlags.NoError;
                            this.outBuffer[0] = (byte)Commands.ClearStatusCodes;
                            this.outBuffer[1] = (byte)(this.g.Status);
                            this.outBuffer[2] = this.g.Crc8.DoCrc8(this.outBuffer, 2);
                            this.port.Write(this.outBuffer, 0, 3);
                    catch
                    /* ignore the whole command */
                break;
            default:
                // Ignore the command
                break;
Perhaps it’s the ReadTimeOut = 0;
The read time-out value was originally set at 500 milliseconds in the Win32 Communications API. This property allows you to set this value. The time-out can be set to any value greater than zero, or set to InfiniteTimeout, in which case no time-out occurs.InfiniteTimeout is the default.
Thank you RoSchmi and Ariane_Medical. I try ReadTimeout=Timeout.Infinite;
Regards, JCP
To avoid characters to be interpreted as control characters you can wrap your file or data as base64 string:
            byte[] textAsBytes = encoding.GetBytes(text);
            encodedText = Convert.ToBase64String(textAsBytes);
