I’m trying to figure out how to use serialization but get an exception I can’t figure out. As far as I can tell, my test program is just like the examples I’ve found on the forum.
namespace SerializeTest
public struct DepthTable
public float depth;
public float PV;
public TimeSpan parkTime;
[Serializable]
public class serMission
public DepthTable[] descendTable = new DepthTable[1];
public DepthTable[] ascendTable = new DepthTable[3];
public serMission(float depth, float PV, TimeSpan parkTime)
descendTable[0].depth = depth;
descendTable[0].PV = PV;
descendTable[0].parkTime = parkTime;
ascendTable[0].depth = depth - 2;
ascendTable[0].PV = PV - (float).01;
ascendTable[0].parkTime = new TimeSpan(0, 0, 0, 0); //days, hours, minutes, seconds
ascendTable[1].depth = depth - 4;
ascendTable[1].PV = PV - (float).02;
ascendTable[1].parkTime = new TimeSpan(0, 0, 0, 0); //days, hours, minutes, seconds
ascendTable[2].depth = depth - 6;
ascendTable[2].PV = PV - (float)0.03;
ascendTable[2].parkTime = new TimeSpan(0, 0, 0, 0); //days, hours, minutes, seconds
TimeSpan ts = new TimeSpan(0, 0, 3, 0);
serMission inMission = new serMission((float)15.0, (float)0.1, ts);
byte[] buffer = Reflection.Serialize(inMission, typeof(serMission));
serMission outMission = (serMission)Reflection.Deserialize(buffer, typeof(serMission));
Debug.Print("Num of descend table elements = " + outMission.descendTable.Length.ToString());
Here’s the exception
Program Started
#### Exception System.Exception - CLR_E_APPDOMAIN_MARSHAL_EXCEPTION (1) ####
#### Message:
#### Microsoft.SPOT.Reflection::Serialize [IP: 0000] ####
#### SerializeTest.Program::Main [IP: 002d] ####
A first chance exception of type ‘System.Exception’ occurred in Microsoft.SPOT.Native.dll
An unhandled exception of type ‘System.Exception’ occurred in Microsoft.SPOT.Native.dll
Thanks for the help
