Its a serial cam, and it returns a jpeg encoded image which is often less than 20K, that should be possible…or am I wrong?
At least you check the image-size before downloading it…?
You are right. The file might fit in memory. The corresponding bitmap will be a challenge depending on total memory use.
[quote=“Ingeborg”]You have 2 days to explain because I have to work on other projects.
[/quote]
Now you are just beeing rude. No one have to explain anything, and demanding people to do your homework is not going to get you anywhere.
@ DAT : Yes, such an example.But: I tried it
and nothing happend:
CODE (how can I put it in an code area???)
using GT = Gadgeteer;
namespace serCam02
public partial class Program
new Thread(VideoStreaming).Start();
int imageCnt;
void VideoStreaming() {
serCam.StartStreaming();
imageCnt = 5;
while (imageCnt > 0)
Thread.Sleep(1000);
long start = Microsoft.SPOT.Hardware.Utility.GetMachineTime().Ticks;
if (serCam.isNewImageReady) {
serCam.isNewImageReady = false;
serCam.StopStreaming();
byte[] data = serCam.dataImage;
int picture_size = serCam.dataImage.Length;
long end = Microsoft.SPOT.Hardware.Utility.GetMachineTime().Ticks;
long duration = (end - start) / 10000;
Debug.Print("duration; " + duration.ToString() + " ms, " + " length: " + picture_size.ToString());
Debug.Print("Picture size = " + serCam.dataImage.Length);
imageCnt--;
OutputWindow:
Der Thread ‘’ (0x2) hat mit Code 0 (0x0) geendet.
Using mainboard GHI Electronics FEZCerberus version 1.1
Program Started
@ Ingeborg -
Nothing happened because you sleep(1000);
that is too high, reduce to 5 or 10 will be fine. It because the camera still scanning and isNewImageReady is always changed. Sleep(1000) it still work but you may wait for few minutes or hours.
