I’m using Fez Spider and trying to run the serial port manually on an extender to talk to an Arduino (I know sorry).
I can’t find any code examples.
I’m trying to use - GTI.Serial serial;
But I can’t see any way to set this up.
Thanks in advance.
Thanks.
This helps a bit. I’m just wondering how I associate the Serial with a socket on the .NET Gadgeteer using the extender.
I done it a couple of years ago and I remembered it being easy.
@ shapingstuff -
See Image. This is a MF Console application using a Fez Spider.
The code shown is GHI example from Support, .NET Micro Framework, UART (Serial)
Connect your extender to Socket 11 - Pin 4 = TX Pin 5 = RX (No code in example image)
EDIT:
I forgot to mention that Socket 11 is COM1.
Thanks for this - exactly what I was looking for.
I was a little confused about COM1 and wither I had to define the socket.
