Befor i got a Fez Domino, i used a Arduino as Input Device for a home automation software. I used it as datalogger for reading a din-rail powermeter. So the Arduino reads the data and sends it over the virtual serial port to my pc. So now i woult like to do this with my new fez domino. But how can i communicate with my pc? The Fez Domino didnt creats a virtual serial port. But the VisualStudio and the MSDepoy Tool can read the Debug Output. Can i read the Debug Ouput with C# on the Pc side? The software on the pc side is written in c#.
Thanks and sorry for my bad english.
Greets
Henning
The connection to your PC is for debugging (which you do not have on arduino) and not a virtual serial port.
FEZ Domino has 3 serial ports so you can pick anyone you like and connect a USB<->serial cable…
Or use the RS232 shield and then you can connect a serial cable to your PC…
Or connect a USB<->serial cable to the USB host on domino and then connect that to your PC serial port…
or use the bluetooth component to make a bluetooth connection and transfer that data that way…
there is really many ways to do this so pick the one you like best
Also, you can change the USB client interface to become a virtual serial port (or many other things) I highly do not recommend you try that for beginners
thanks for the quick reply.
I was hopping that i can use the mini Usb Port for powering and communicate with the pc.
I think i use my old arduino as usb-serial converter, as i read it in another thread here.
I have one more small question about serial communication.
I try to transfer a text, from C# on the PC side to the domino. The text is 1024 bytes long. But on the domino side always be only 256 bytes received.
Can i configure this somewhere or do i have to split the text in 256 byte blocks?
you need to remember Fez doesn’t have unlimited memory. You should be handling your data in “chunks” somehow. There’s nothing I can think of that would FORCE you to have only 256 char blocks, so if you want to have a block of 1024 chars you can - but you need to handle it properly!
Thanks that works great, a little bit slow but okay.
But i have another question and i dont want to start a extra thread for that.
Is there any trick to transfer the DateTime from my pc to the fez?
When i send DateTime.Now.Ticks.ToString() from my pc to the fez and i parse it there as long, then i have exactly the same number in it.
But when i try to do new DateTime(LongWithTheTicks) then i got an exception:
System.ArgumentOutOfRangeException Ticks must be between DateTime.MinValue.Ticks and DateTime.MaxValue.Ticks.
I found out that the Ticks of my pc are 634154061848395921 and with the same Date and Time on the fez it is 129242902200000000.
It is always better to start new thread so others can benefit from your question.
PCs and embedded system are from 2 separate world. Yes the NETMF helps in bringing them closer but they are still different.
Whenever you run into something similar you want to think of a way where you put the load on the PC (even use “unsafe” code) to generate something that is easily passable by the device.
I would try to figure out the ticks on NETMF and then convert the ticks from your PC to match the device then send to the device.
Thanks for the reply.
I found a way to set the time.
My “trick” is to get the milliseconds of the timespan from 01.01.1900 00:00:00:00 to Now and send it to the fez and there i add them to the same MinValue.
Thanks, and nexttime i will start a new thread
Henning
