I want to use the USB client on the Domino and therefore need to deploy an Debug over a serial connection. I placed the mode jumper. I use the sparkfun ft232 breakout board.
The board is connect correctly because I had bidirectional serial communication over the UART.
Deploying gives gives an error and nothing is deployed. Also no respons is recieved if I ping with
the MSDeploy utillity.
Then the problem must be in your RS232 shield or in the cable you are suing.
If you open a terminal program (teraterm) at 115200 and reset your device, you will see a lot of messages on the terminal. If you don’t then you have connection problem.
Before i tested the FTDI bord with an application that writes “Hello world” from the Domino to the PC
When I start a terminal (UTF) then I still receive “Hello world” deploying a new application to the domino is impossible however. pushing reset or even remove power for 5 sec doesn’t help. The Domino starts sending xxxxxxxxxxxxxxxxxxxxx and then “Hello world” when its restarted.
I think this proves communication is OK.
