I have a FEZ Panda II device I would like to debug using a serial connection, instead of USB.
This is the current setup.
- Connected a FTDI Friend (FTDI Friend + extras [v1.0] : ID 284 : $14.75 : Adafruit Industries, Unique & fun DIY electronics and kits) to COM1 on the Panda
- Connected MOD pin to GND pin.
- Connected a USB cable between the FTDI Friend and Windows PC.
The FTDI Friend is recognized as a virtual serial port (COM7) in Windows, and seems to be working correctly.
In Visual Studio 2010 i changed the deployment transport to Serial, and selected COM7 as device.
When deploying it shows the following error: Error 1, Unable to communicate with device - Serial:COM7.
I tried running the MFDeploy.exe tool, but it can not ping the device. Pinging… Error: No response from device
If I start Tera Term, and connect to COM7 using 1152000, 8, N, 1 and reset the Panda - it receives a lot of data:
Debug: COM1
LCD: 0x0
IP: 0.0.0.0
MAC: 00.00.00.00.00.00
Managed heap size: 64412
Custom heap size: 0
.NetMF v4.1.2821.0
USBizi, Build Date:
Dec 22 2011 16:30:33
ARM Compiler version 410561
TinyCLR (Build 4.1.2821.0)
Starting...
Created EE.
Started Hardware.
MSdbgV1??k
1Ë_MSdbgV1ÊP1Ë_MSdbgV1??p1Ë_MSdbgV1Þ°1Ë_MSdbgV1ØùF1Ë_MSdbgV1ÒÜ]1Ë_MSdbgV1Ô?«1Ë_MSdbgV1öÜ51
Ë_MSdbgV1ðm*21MË_MSdbgV1úH1:1M
Ë_MSdbgV1ü«Ç=1M
Ë_MSdbgV1î*1M
Ë_MSdbgV1âÄê%1Ë_MSdbgV1ä'"1Ë_MSdbgV1¦¦u1Ë_MSdbgV1 Eór1Ë_MSdbgV1ª`èz1Ë_MSdbgV1¬}1Ë_No debugger!
Create TS.
Loading start at 4eb34, end 56d0c
Attaching file.
Assembly: mscorlib (4.1.2821.0) (3880 RAM - 33236 ROM - 19134 METADATA)
AssemblyRef = 0 bytes ( 0 elements)
TypeRef = 0 bytes ( 0 elements)
FieldRef = 0 bytes ( 0 elements)
MethodRef = 0 bytes ( 0 elements)
TypeDef = 1112 bytes ( 139 elements)
FieldDef = 272 bytes ( 135 elements)
MethodDef = 1572 bytes ( 786 elements)
Attributes = 0 bytes ( 0 elements)
TypeSpec = 16 bytes ( 4 elements)
Resources = 232 bytes ( 29 elements)
Resources Files = 16 bytes ( 2 elements)
Resources Data = 437 bytes
Strings = 1551 bytes
Signatures = 2126 bytes
ByteCode = 11702 bytes
(Removed assembly meta data)
Ready.
- Am I doing something wrong? The device seems to be configured for serial debugging, but I can not deploy to it.
Edit: Added blurry image of setup.
