Serial Debug on SC13048
I want the USB for COM CDC for my Application and move the debug to UART1.
It is not clear to me what to do with the MOD pin, I tried a bunch of things
https://docs.ghielectronics.com/software/tinyclr/tutorials/device-info.html
I would measure the voltage on the MOD pin in the factory state. If it is 3.3v the I would ground the pin for serial debug. If zero, apply 3.3v.
Looks like this page is missing that info Debugging
A low on the pin will change the interface to serial.
Thanks, everything works, debugging on UART-1 works.
USB comes up as a COM port on the PC.
CDC is typically limited to 64 KBytes/second
is that 512kbps
