sdCard.MountSDCard();
serCam.StartStreaming();
byte[] data = serCam.dataImage;
string name = "img.bmp";
sdCard.GetStorageDevice().WriteFile(name, data);
serCam.StopStreaming();
sdCard.UnmountSDCard();
the img.bmp file will be saved on sd card in 13Kb, but usually I receive error about damaged file "windows ca not open the file , it is damaged or …"
can eanybody help me?
thanks
thanks for answers
It seems that the problem is not about writing byte array on sd card.
the property of :
always return FALSE !!!!
apart from that, I've read this note :
https://www.ghielectronics.com/docs/176/serial-camera-module
but i don't have this methods :
```cs]https://www.ghielectronics.com/docs/176/serial-camera-module[/code
Is it in a new version of .net micro framework?
Thanks very much for your attentions…
I’m using net micro framework sdk 4.2
Is that method just for sdk ver 4.3?
Mike : I’'m writing the file on sd and I can see it when I connect sd to my pc. Ut when i want to open it, I recieve that error
