Hi, Thanks for help.
I tried and I’ve got error message:
A first chance exception of type ‘System.Exception’ occurred in Microsoft.SPOT.Graphics.dll
An unhandled exception of type ‘System.Exception’ occurred in Microsoft.SPOT.Graphics.dll
Any idea?
Best regards,
Peter
details:
Found debugger!
Create TS.
Loading start at 20175958, end 201a2c9c
Assembly: mscorlib (4.2.0.0) Assembly: Microsoft.SPOT.Native (4.2.0.0) Assembly: Microsoft.SPOT.Hardware (4.2.0.0)
Assembly: Microsoft.SPOT.Graphics (4.2.0.0) Assembly: Microsoft.SPOT.TinyCore (4.2.0.0)
Assembly: Microsoft.SPOT.IO (4.2.0.0) Assembly: System.IO (4.2.0.0) Assembly: Microsoft.SPOT.Hardware.Usb (4.2.0.0)
Assembly: Microsoft.SPOT.Hardware.SerialPort (4.2.0.0) Assembly: Microsoft.SPOT.Touch (4.2.0.0)
Assembly: Microsoft.SPOT.Ink (4.2.0.0) Assembly: Microsoft.SPOT.Hardware.PWM (4.2.0.1)
Assembly: Microsoft.SPOT.Hardware.OneWire (4.2.0.0) Assembly: System.Xml (4.2.0.0)
Assembly: Microsoft.SPOT.Time (4.2.0.0) Assembly: Microsoft.SPOT.Net (4.2.0.0)
Assembly: System (4.2.0.0) Assembly: Microsoft.SPOT.Net.Security (4.2.0.0)
Assembly: System.Net.Security (4.2.0.0) Loading Deployment Assemblies.
Attaching deployed file.
Assembly: GHI.OSHW.Hardware (4.2.3.0) Attaching deployed file.
Assembly: Gadgeteer (2.42.0.0) Attaching deployed file.
Assembly: Gadgeteer.WebClient (2.42.0.0) Attaching deployed file.
Assembly: System.Http (4.2.0.0) Attaching deployed file.
Assembly: Gadgeteer.WebServer (2.42.0.0) Attaching deployed file.
Assembly: Gadgeteer.Serial (2.42.0.0) Attaching deployed file.
Assembly: GTM.GHIElectronics.Potentiometer (1.0.0.0) Attaching deployed file.
Assembly: testapp (1.0.0.0) Attaching deployed file.
Assembly: GTM.GHIElectronics.Button (1.0.0.0) Attaching deployed file.
Assembly: GTM.GHIElectronics.SerCam (1.0.0.0) Attaching deployed file.
Assembly: GHIElectronics.Gadgeteer.FEZHydra (1.0.6.0) Resolving.
GC: 1msec 422496 bytes used, 5868636 bytes available
Type 0F (STRING ): 24 bytes
Type 15 (FREEBLOCK ): 5868636 bytes
Type 17 (ASSEMBLY ): 33144 bytes
Type 1E (BINARY_BLOB_HEAD ): 389256 bytes
GC: performing heap compaction…
Ready.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files\Microsoft .NET Micro Framework\v4.2\Assemblies\le\mscorlib.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Native.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Hardware.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Graphics.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.TinyCore.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.IO.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files\Microsoft .NET Micro Framework\v4.2\Assemblies\le\System.IO.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Hardware.Usb.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Hardware.SerialPort.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Touch.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Ink.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Hardware.PWM.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Hardware.OneWire.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files\Microsoft .NET Micro Framework\v4.2\Assemblies\le\System.Xml.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Time.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Net.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files\Microsoft .NET Micro Framework\v4.2\Assemblies\le\System.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Net.Security.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files\Microsoft .NET Micro Framework\v4.2\Assemblies\le\System.Net.Security.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files\GHI Electronics\GHI OSHW NETMF v4.2 SDK\Assemblies\le\GHI.OSHW.Hardware.dll’
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files\Microsoft .NET Gadgeteer\Core\Assemblies.NET Micro Framework 4.2\le\Gadgeteer.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files\Microsoft .NET Micro Framework\v4.2\Assemblies\le\System.Http.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files\Microsoft .NET Gadgeteer\Core\Assemblies.NET Micro Framework 4.2\le\Gadgeteer.WebClient.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files\Microsoft .NET Gadgeteer\Core\Assemblies.NET Micro Framework 4.2\le\Gadgeteer.WebServer.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\gadgeteer-22735\Main\Modules\GHIElectronics\SerCam\Software\SerCam\SerCam_42\bin\Debug\le..\Gadgeteer.Serial.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files\GHI Electronics\GHI .NET Gadgeteer SDK\Modules\Potentiometer\NETMF 4.2\le\GTM.GHIElectronics.Potentiometer.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\gadgeteer-22735\Main\Modules\GHIElectronics\SerCam\Software\SerCam\SerCam_42\bin\Debug\le\GTM.GHIElectronics.SerCam.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files\GHI Electronics\GHI .NET Gadgeteer SDK\Modules\Button\NETMF 4.2\le\GTM.GHIElectronics.Button.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files\GHI Electronics\GHI .NET Gadgeteer SDK\Mainboards\FEZHydra\NETMF 4.2\le\GHIElectronics.Gadgeteer.FEZHydra.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\gadgeteer-22735\Main\Modules\GHIElectronics\SerCam\Software\testapp\bin\Debug\le\testapp.exe’, Symbols loaded.
Using mainboard GHI Electronics FEZHydra version 1.2
Program Started
potPercent :0
potPercent :0
#### Exception System.Exception - CLR_E_FAIL (6) ####
#### Message:
#### Microsoft.SPOT.Bitmap::.ctor [IP: 0000] ####
#### Gadgeteer.Modules.GHIElectronics.SerCam::ts [IP: 001d] ####
