I have a FEZ Cobra + 7" touch display, but I’m not so satisfied about the sensitivity/reaction time of the FEZ/display. Sometimes the response is very slow, making me think I have to push the display harder.
I can think of two reasons:
[ol]
The sensitivity of the display is not so good - anyone knows a way to control this?
FEZ reacts too slow, which seems odd, as FEZ is not doing anything besides showing the display and waiting for one button (of three) to be pressed.
[/ol]
If you’re using the MS sample you’re using WPF. The second you load the TinyCore reference you’re going to lose performance; whether you use it or not.
I have a sample for gathering touch information sans WPF in Code.TinyClr.com. The GHI sample also works w/o WPF as does Pyxis 2. (pyxis2.codeplex.com)
Yes that would mean a different screen or replacing the existing touch screen on top of the LCD w/ a capacitive one.
My customer stil isn’t satisfied with the sensitivity of the display yet.
Today it seemed to make a difference if the customer takes off his shoes.
Shoes on => bad sensitivity of the display
Shoes off => much better sensitivity of the display
This makes me think there might be some influence of a kind of static electricity. Is that possible?
Does it make any sense to ground the display? In what way should that be done?
Resistive touch screens depend on pressure, so taking off your shoes probably just smells bad. Some 7" touch panels have somewhat lousy precision, depending on whether you are using 10-bit or 12-bit resolution ADC - but the response should not suffer. Unless the your software is ignoring values that don’t change. Is he using a stylus or his finger (/ toe)?
Write a small routine to just read the position of the stylus and see if there is a problem with the required sensitivity over the surface. Maybe the touch layer is defective?
