i have Cerbuino Net and CellularRadio module. I updated bord to the newest firmware and installed newst SDK. I need two functions for my project, to send and to receive SMS.
I dont have experience with gadeteer developing but i managed to start up module and to receive SMS. I can’t send SMS and i can only receive one SMS and when i send another one i get exception and i have to reset bord and then i can receive one message. I can also receive one call and after that i have to reset.
using System.Collections;
using Microsoft.SPOT.Touch;
using Gadgeteer.Networking;
using GT = Gadgeteer;
namespace Cerbuino_SMS_test
public partial class Program
Debug.Print("Program started");
cellularRadio.DebugPrintEnabled = true;
cellularRadio.PowerOn(40);
cellularRadio.GsmNetworkRegistrationChanged += cellularRadio_GsmNetworkRegistrationChanged;
cellularRadio.ImeiRetrieved += cellularRadio_ImeiRetrieved;
cellularRadio.ModuleInitialized += cellularRadio_ModuleInitialized;
cellularRadio.OperatorRetrieved += cellularRadio_OperatorRetrieved;
cellularRadio.PhoneActivityRetrieved += cellularRadio_PhoneActivityRetrieved;
cellularRadio.PinStateRetrieved += cellularRadio_PinStateRetrieved;
cellularRadio.SignalStrengthRetrieved += cellularRadio_SignalStrengthRetrieved;
cellularRadio.ClockRetrieved += cellularRadio_ClockRetrieved;
cellularRadio.SmsListRetrieved += cellularRadio_SmsListRetrieved;
cellularRadio.SmsReceived += cellularRadio_SmsReceived;
cellularRadio.SmsRetrieved += cellularRadio_SmsRetrieved;
cellularRadio.IncomingCall += cellularRadio_IncomingCall;
cellularRadio.CallConnected += cellularRadio_CallConnected;
cellularRadio.CallEnded += cellularRadio_CallEnded;
GT.Timer t = new GT.Timer(100000);
t.Tick += t_Tick;
t.Start();
void cellularRadio_GsmNetworkRegistrationChanged(CellularRadio sender, CellularRadio.NetworkRegistrationState networkState)
switch (networkState)
case CellularRadio.NetworkRegistrationState.Error:
Debug.Print("NETWORK_STATE: Error");
break;
case CellularRadio.NetworkRegistrationState.NotSearching:
Debug.Print("NETWORK_STATE: NotSearching");
break;
case CellularRadio.NetworkRegistrationState.Registered:
Debug.Print("NETWORK_STATE: Registered");
break;
case CellularRadio.NetworkRegistrationState.RegistrationDenied:
Debug.Print("NETWORK_STATE: RegistrationDenied");
break;
case CellularRadio.NetworkRegistrationState.Roaming:
Debug.Print("NETWORK_STATE: Roaming");
break;
case CellularRadio.NetworkRegistrationState.Searching:
Debug.Print("NETWORK_STATE: Searching");
break;
case CellularRadio.NetworkRegistrationState.Unknown:
Debug.Print("NETWORK_STATE: Unknown");
break;
default:
Debug.Print("NETWORK_STATE: default");
break;
private void cellularRadio_ImeiRetrieved(CellularRadio sender, string imei)
Debug.Print("IMEI: " + imei);
private void cellularRadio_ModuleInitialized(CellularRadio sender)
Debug.Print("MODULE_INITIALIZED");
private void cellularRadio_OperatorRetrieved(CellularRadio sender, string operatorName)
Debug.Print("OPERATOR_RETRIEVED: " + operatorName);
private void cellularRadio_PhoneActivityRetrieved(CellularRadio sender, CellularRadio.PhoneActivityType activity)
switch (activity)
case CellularRadio.PhoneActivityType.CallInProgress:
Debug.Print("PHONE_ACTIVITY_RETRIEVED: CallInProgress");
break;
case CellularRadio.PhoneActivityType.CommLineBusy:
Debug.Print("PHONE_ACTIVITY_RETRIEVED: CommLineBusy");
break;
case CellularRadio.PhoneActivityType.Ready:
Debug.Print("PHONE_ACTIVITY_RETRIEVED: Ready");
break;
case CellularRadio.PhoneActivityType.Ringing:
Debug.Print("PHONE_ACTIVITY_RETRIEVED: Ringing");
break;
case CellularRadio.PhoneActivityType.Unknown:
Debug.Print("PHONE_ACTIVITY_RETRIEVED: Unknown");
break;
default:
Debug.Print("PHONE_ACTIVITY_RETRIEVED: default");
break;
private void cellularRadio_PinStateRetrieved(CellularRadio sender, CellularRadio.PINState pinState)
switch (pinState)
case CellularRadio.PINState.NotPresent:
Debug.Print("PIN_STATE_RETRIEVED: NotPresent");
break;
case CellularRadio.PINState.PH_PIN:
Debug.Print("PIN_STATE_RETRIEVED: PH_PIN");
break;
case CellularRadio.PINState.PH_PUK:
Debug.Print("PIN_STATE_RETRIEVED: PH_PUK");
break;
case CellularRadio.PINState.PIN:
Debug.Print("PIN_STATE_RETRIEVED: PIN");
break;
case CellularRadio.PINState.PIN2:
Debug.Print("PIN_STATE_RETRIEVED: PIN2");
break;
case CellularRadio.PINState.PUK:
Debug.Print("PIN_STATE_RETRIEVED: PUK");
break;
case CellularRadio.PINState.PUK2:
Debug.Print("PIN_STATE_RETRIEVED: PUK2");
break;
case CellularRadio.PINState.Ready:
Debug.Print("PIN_STATE_RETRIEVED: Ready");
break;
default:
Debug.Print("PIN_STATE_RETRIEVED: default");
break;
private void cellularRadio_SignalStrengthRetrieved(CellularRadio sender, CellularRadio.SignalStrengthType signalStrength)
switch (signalStrength)
case CellularRadio.SignalStrengthType.Error:
Debug.Print("SIGNAL_STRENGTH_RETRIEVED: Error");
break;
case CellularRadio.SignalStrengthType.Strong:
Debug.Print("SIGNAL_STRENGTH_RETRIEVED: Strong");
break;
case CellularRadio.SignalStrengthType.Unknown:
Debug.Print("SIGNAL_STRENGTH_RETRIEVED: Unknown");
break;
case CellularRadio.SignalStrengthType.VeryStrong:
Debug.Print("SIGNAL_STRENGTH_RETRIEVED: VeryStrong");
break;
case CellularRadio.SignalStrengthType.VeryWeak:
Debug.Print("SIGNAL_STRENGTH_RETRIEVED: VeryWeak");
break;
case CellularRadio.SignalStrengthType.Weak:
Debug.Print("SIGNAL_STRENGTH_RETRIEVED: Weak");
break;
default:
Debug.Print("SIGNAL_STRENGTH_RETRIEVED: default");
break;
private void cellularRadio_ClockRetrieved(CellularRadio sender, DateTime clock)
Debug.Print("CLOCK_RETRIEVED: " + clock.ToString("dd.MM.yyyy HH:mm:ss"));
private void cellularRadio_SmsListRetrieved(CellularRadio sender, ArrayList smsList)
Debug.Print("SMS_LIST_RETRIEVED - " + smsList.Count.ToString());
foreach (CellularRadio.Sms sms in smsList)
Debug.Print(" FROM: " + sms.TelephoneNumber + " MSG: " + sms.TextMessage);
private void cellularRadio_SmsReceived(CellularRadio sender, CellularRadio.Sms message)
Debug.Print("SMS_RECEIVED");
Debug.Print(" TIME: " + message.Timestamp.ToString("dd.MM.yyyy HH:mm:ss"));
Debug.Print(" FROM: " + message.TelephoneNumber);
Debug.Print(" MESSAGE: " + message.TextMessage);
switch (message.Status)
case CellularRadio.SmsState.All:
Debug.Print(" STATUS: All");
break;
case CellularRadio.SmsState.ReceivedRead:
Debug.Print(" STATUS: ReceivedRead");
break;
case CellularRadio.SmsState.ReceivedUnread:
Debug.Print(" STATUS: ReceivedUnread");
break;
case CellularRadio.SmsState.StoredSent:
Debug.Print(" STATUS: StoredSent");
break;
case CellularRadio.SmsState.StoredUnsent:
Debug.Print(" STATUS: StoredUnsent");
break;
default:
Debug.Print(" STATUS: default");
break;
private void cellularRadio_SmsRetrieved(CellularRadio sender, CellularRadio.Sms message)
Debug.Print("SMS_RETREIVED");
break;
break;
break;
break;
break;
default:
break;
private void cellularRadio_IncomingCall(CellularRadio sender, string caller)
Debug.Print("INCOMING_CALL: " + caller);
private void cellularRadio_CallConnected(CellularRadio sender, string number)
Debug.Print("CALL_CONNECTED: " + null);
private void cellularRadio_CallEnded(CellularRadio sender, CellularRadio.CallEndType reason)
switch (reason)
case CellularRadio.CallEndType.Busy:
Debug.Print("CALL_ENDED: Busy");
break;
case CellularRadio.CallEndType.NoCarrier:
Debug.Print("CALL_ENDED: NoCarrier");
break;
case CellularRadio.CallEndType.NoDialTone:
Debug.Print("CALL_ENDED: NoDialTone");
break;
default:
Debug.Print("CALL_ENDED: default");
break;
void t_Tick(GT.Timer timer)
Debug.Print("TEST METODA");
cellularRadio.RetrieveImei();
cellularRadio.RetrieveOperator();
cellularRadio.RetrievePhoneActivity();
cellularRadio.RetrievePinState();
cellularRadio.RetrieveSignalStrength();
cellularRadio.RetrieveClock();
cellularRadio.SendSms("098805066", "probna poruka");
Debug output (on timer event i tried to send sms and failed, then i received one message and after i wanted to receive one more i get exception:
[quote]Program started
CellularRadio : Turning ON
CellularRadio : Turning module on
CellularRadio : <ÿ>
CellularRadio : <ÿÿ>
CellularRadio : <ÿ>
CellularRadio : SENT: AT
CellularRadio : <AT
OK
CellularRadio : SENT: AT+CMGF=1
CellularRadio : <AT+CMGF=1
OK
CellularRadio : SENT: AT+CSDH=0
CellularRadio : <AT+CSDH=0
OK
CellularRadio : SENT: AT+CPBS=“SM”
CellularRadio : <AT+CPBS=“SM”
OK
CellularRadio : SENT: AT+CPMS=“SM”
CellularRadio : <AT+CPMS=“SM”
ERROR
AT+C>
CellularRadio : SENT: AT+CNMI=2,1,0,1,0
CellularRadio : <NMI=2,1,0,1,0
OK
AT+COLP=1
OK
CellularRadio : SENT: AT+COLP=1
CellularRadio : <AT+CGREG=1
OK
CellularRadio : SENT: AT+CGREG=1
CellularRadio : <AT+CREG=1
OK
CellularRadio : SENT: AT+CREG=1
The thread ‘’ (0x5) has exited with code 0 (0x0).
CellularRadio : <
+CREG: 0
CellularRadio : <
+CREG: 2
CellularRadio : <
+CR>
CellularRadio : <EG: 1
+CGREG: 0
CellularRadio : <
+CGREG: 1
CellularRadio : <
+CREG: 1
TEST METODA
CellularRadio : SENT: AT+GSN
CellularRadio : <AT+GSN
013227005458744
OK
CellularRadio : SENT: AT+COPS?
CellularRadio : <AT+COPS?
+COPS: 0,0,“HR VIP”
OK
CellularRadio : SENT: AT+CPAS
CellularRadio : <AT+CPAS
+CPAS: 0
OK
CellularRadio : R:[0]
CellularRadio : SENT: AT+CPIN?
CellularRadio : <AT+CPIN?
CellularRadio : SENT: AT+CSQ
CellularRadio : <
+CPIN: READY
OK
AT+CSQ
+CSQ: 31,0
OK
CellularRadio : SENT: AT+CCLK?
CellularRadio : <AT+CCLK?
+CCLK: “00/01/01,06:44:48+00”
OK
CellularRadio : <AT+CMGS="+098805066"
IMEI: 013227005458744
OPERATOR_RETRIEVED: "HR VIP"
CLOCK_RETRIEVED: 01.01.2000 06:44:48
CellularRadio :
CellularRadio : <
ERROR
CellularRadio : <
+CMTI: “SM”,8
CellularRadio : SENT: AT+CMGR=8,1
CellularRadio : <AT+CMGR=8,1
CellularRadio : <
+CMGR: “REC UNREAD”,"+38598805066","","14/09/20,20:22:54+08"
Test
OK
CellularRadio : REQ: 8
SMS_RECEIVED
TIME: 20.09.2014 20:22:54
MESSAGE: Test
CellularRadio : <
+CMTI: “SM”,9
CellularRadio : SENT: AT+CMGR=9,1
CellularRadio : <AT+CMGR=9,1
CellularRadio : <
+CMGR: “REC UNREAD”,"+38598805066","",>
A first chance exception of type ‘System.ArgumentOutOfRangeException’ occurred in mscorlib.dll
An unhandled exception of type ‘System.ArgumentOutOfRangeException’ occurred in mscorlib.dll
Uncaught exception
The thread ‘’ (0x4) has exited with code 0 (0x0).
[/quote]
