Hello, I’ve got problem sending a post request with sdk 4.3.
I used the code for the 4.2 (working), is there a fix or another way to do it? Thanks
10050 should be connection down, but I tested the network code separately and it works and the exception raises up after the reqData.SendRequest().
POSTContent postData = POSTContent.CreateBinaryBasedContent(picture.PictureData); HttpRequest reqData = HttpHelper.CreateHttpPostRequest("http://192.168.43.206/takephoto/index.php", postData, "image/bmp"); reqData.ResponseReceived += new HttpRequest.ResponseHandler(reqData_ResponseReceived); reqData.SendRequest();
#### Exception System.Net.Sockets.SocketException - CLR_E_FAIL (10) ####
#### Message:
#### Microsoft.SPOT.Net.SocketNative::poll [IP: 0000] ####
#### System.Net.Sockets.Socket::Poll [IP: 0011] ####
#### System.Net.Sockets.Socket::Connect [IP: 0029] ####
#### System.Net.HttpWebRequest::SubmitRequest [IP: 0019] ####
#### System.Net.HttpWebRequest::GetRequestStream [IP: 0008] ####
#### SocketException ErrorCode = 10050
A first chance exception of type ‘System.Net.Sockets.SocketException’ occurred in Microsoft.SPOT.Net.dll
#### Exception System.Net.WebException - 0x00000000 (10) ####
#### Message: connection failed
#### System.Net.HttpWebRequest::EstablishConnection [IP: 0172] ####
A first chance exception of type ‘System.Net.WebException’ occurred in System.Http.dll
An exception occured while connecting to the Internet. Please, make sure that a valid URL is used and a network connection is up.
connection failed
The thread ‘’ (0xa) has exited with code 0 (0x0).
The program ‘[2] Micro Framework application: Managed’ has exited with code 0 (0x0).
