Hi all, software developer, no experience in electronics, playing with this field for the very first time.
I have a FEZ Spider with various modules, but I have a Seeed oledDisplay in socket 9, and a GHI Flash Module in socket 6, both SPI.
These were working fine, until I started using dotnetwarrior FlashFileSystem. I replaced the flash module on the designer diagram with the FlashFileSystem and hooked it back up to socket 6.
Now, the FlashFileSystem is working fine, but I can no longer write anything to the oledDisplay, it just stays blank. It appears to initialise ok, I get no errors anywhere, just a blank screen.
Should I be able to use both of these together, or is there some sort of hardware limitation going on, or something else I’ve missed?
Thanks in advance…
