Hi, i’m building a CAN gateway for a prototype but on the EMX10-DS-129 only one CAN port is actual
on the board, for the second port, can we use a gadgeteer module like the CANDW-GM-311 for this?
Are there people having exprerience with these modules in automotive solutions? (SAEJ1939)
Looking at the lower left corner of the EMX development system you will see a header. This header exposes the pins for the second CAN channel on the EMX module.
But imho you don’t really need much knowledge about 1939 to use on netmf.
You probably set a filter on CAN listening to the ID of your output controller and broadcast messages
in the format specified in the output controllers manual.
At most you need to have a deeper look at the PGN and SPN definitions that you will actual use.
