Bearer of Bad Tidings … Or is it just me?
I had some code that ran on my G120E Dev. Board when using firmware 4.3.7.10.
To me it appears there is something wrong with pin assignments (But what do I know?)
Using the same code with 4.3.8.0 fails.
Test example of the code I used to show the errors. The pin assignments worked in 4.3.7.10
Maybe it is me but I think it should work without exceptions.
Thanks for your time.
using System.Diagnostics;
using GHI.Networking; //Version 4.3.8.0
using GHI.Pins; //Version 4.3.8.0
/* Updated from 4.3.7.10
Loader (TinyBooter) version information:
4.3.8.0 on this computer.
4.3.8.0 on this device.
>>> The Loader (TinyBooter) is up to date. <<<
Firmware (TinyCLR) version information:
>>> The Firmware (TinyCLR) is up to date. <<<
//Exception System.Exception - CLR_E_PIN_UNAVAILABLE (1) Button.Left value = 85
//interrupt_ports[2] = new InterruptPort(Button.Left, true, Port.ResistorMode.PullUp, Port.InterruptMode.InterruptEdgeHigh);
namespace MFConsoleRS911Error
private const Cpu.Pin WIFI_CS = G120E.Gpio.P3_30; //SPI_CS (Slave Select)
private const Cpu.Pin WIFI_RESET = G120E.Gpio.P4_31; //RESET#
private const Cpu.Pin SPI_INTR = G120E.Gpio.P2_30; //SPI_INTR
//private static OutputPort WIFIReset = new OutputPort(G120E.Gpio.P4_31, true);
private static GHI.Networking.WiFiRS9110 wifi;
Version ver = Microsoft.SPOT.Hardware.SystemInfo.Version;
Debug.Print("Version");
Debug.Print("Major: " + ver.Major.ToString());
Debug.Print("Minor: " + ver.Minor.ToString());
Debug.Print("Build: " + ver.Build.ToString());
Debug.Print("Revision: " + ver.Revision.ToString());
Debug.Print("Big Endian: " + Microsoft.SPOT.Hardware.SystemInfo.IsBigEndian.ToString());
Debug.Print("G120E clock: " + Microsoft.SPOT.Hardware.Cpu.SystemClock);
Debug.Print(Resources.GetString(Resources.StringResources.String1) + "\n");
WiFiTest1();
WiFiTest2();
Thread.Sleep(-1);
private static void WiFiTest1()
try
//wifi = new WiFiRS9110(SPI.SPI_module.SPI2, WIFI_CS, SPI_INTR, WIFI_RESET); //Has Exception (WIFI_RESET)
wifi = new WiFiRS9110(SPI.SPI_module.SPI2, WIFI_CS, SPI_INTR); //No Exception
Debug.Print("\nWiFiTest1(): " + "No Exception\n");
catch (Exception e)
Debug.Print("WiFiTest1(): Exception " + e.Message);
Debug Output
Using: wifi = new WiFiRS9110(SPI.SPI_module.SPI2, WIFI_CS, SPI_INTR);
#### Exception System.Exception - CLR_E_PIN_UNAVAILABLE (1) ####
#### Message:
#### Microsoft.SPOT.Hardware.Port::.ctor [IP: 0000] ####
#### Microsoft.SPOT.Hardware.OutputPort::.ctor [IP: 0006] ####
#### GHI.Networking.WiFiRS9110::.ctor [IP: 00c5] ####
#### GHI.Networking.WiFiRS9110::.ctor [IP: 000e] ####
#### MFConsoleRS911Error.Program::WiFiTest1 [IP: 000f] ####
#### MFConsoleRS911Error.Program::Main [IP: 0094] ####
A first chance exception of type 'System.Exception' occurred in Microsoft.SPOT.Hardware.dll
WiFiTest1(): Exception Exception was thrown: System.Exception
#### Exception System.NullReferenceException - CLR_E_NULL_REFERENCE (1) ####
#### Message:
#### MFConsoleRS911Error.Program::WiFiTest2 [IP: 0008] ####
#### MFConsoleRS911Error.Program::Main [IP: 0098] ####
A first chance exception of type 'System.NullReferenceException' occurred in MFConsoleRS911Error.exe
private static void WiFiTest2()
try
wifi.Open();
Debug.Print("\nwifi.Open(): " + "No Exception\n");
catch (Exception e)
Debug.Print("\nwifi.Open() Exception: " + e.Message);
Debug Output
WiFiTest1(): No Exception
#### Exception GHI.Networking.WiFiRS9110+HardwareFailureException - 0x00000000 (1) ####
#### Message:
#### GHI.Networking.WiFiRS9110::UpdateInternalMacAddress [IP: 001c] ####
#### GHI.Networking.BaseInterface::Open [IP: 002a] ####
A first chance exception of type 'GHI.Networking.WiFiRS9110.HardwareFailureException' occurred in GHI.Networking.dll
wifi.Open() Exception: Exception was thrown: GHI.Networking.WiFiRS9110+HardwareFailureException
EDIT.. Ignore the following. This was MY error due to a stray bit of code
/* Also causes exception
