Im using a cobra 2 and a spider. While it was easy to fix SD for the spider.
Im at a complete stand still on trying to get the Cobras onboard SDcard reader to accept the card.
And i cant find any real good information on it either.
Not sure if it matters but im using 4.2.11.2.
Sorry for the bad phrasing, I cant get the SDreader to init.
Don’t know how to explain it.
but with the spider its just
SDCard sdC = new SDcard(socket);
This wont work on the cobra i figured due to the fact its on board.
Yea, found that post to. But for some reason i cant find Mainboard.SDCardMounted
am i missing a namespace. i have included the once i thought had something to do with SD.
If you are using plain NETMF, then you need to include GHI.Hardware as a reference and add ‘using GHI.IO.Storage;’ to your program - that’s where SDCard is defined.
Guess ill have to keep looking.
The events aint there. even included them, removed and included them again still nothing.
Might just keep working on the spider instead.
I can’t find the original post in the forum at the moment but I lifted this code when I first got the CobraII
namespace <Your Namespace Here >
class sdDetect
private PersistentStorage sdPS;
static bool sdEjectRequest = false;
//private static ManualResetEvent _MediaInsertedEvent = null;
#region Public SD Interface
public sdDetect()
// Start auto mounting thread
new Thread(SDMountThread).Start();
public void UnMount()
if (sdPS != null)
sdPS.UnmountFileSystem();
#endregion
#region SD Card Routines
/// <summary>
/// This Thread constantly polls for an SD Card insertion or Eject.
/// </summary>
void SDMountThread()
sdPS = null;
const int POLL_TIME = 500; // check every 500 millisecond
bool sdExists;
try // If SD card was removed while mounting, it may throw exceptions
sdExists = PersistentStorage.DetectSDCard();
if (sdExists && sdEjectRequest)
sdExists = false;
else if (!sdExists && sdEjectRequest && sdPS == null)
// make sure it is fully inserted and stable
if (sdExists && !sdEjectRequest)
Thread.Sleep(250);
if (sdExists && sdPS == null)
sdPS = new PersistentStorage("SD");
sdPS.MountFileSystem();
else if (!sdExists && sdPS != null)
sdPS.Dispose();
sdPS = null;
catch
if (sdPS != null)
sdPS.Dispose();
sdPS = null;
Thread.Sleep(POLL_TIME);
#endregion
public partial class Program
static sdDetect sdCard;
static VolumeInfo sdCardVolume;
RemovableMedia.Insert += RemovableMedia_Insert;
RemovableMedia.Eject += RemovableMedia_Eject;
sdCard = new sdDetect();
private void RemovableMedia_Eject(object sender, MediaEventArgs e)
sdCardVolume = null;
Debug.Print("Card Ejected2");
private void RemovableMedia_Insert(object sender, MediaEventArgs e)
sdCardVolume = e.Volume;
Debug.Print("Card Inserted.");
Hope this helps.
These events? (located in Microsoft.Spot.IO)
// Subscribe to RemovableMedia events
4.3 has changed a few things.
@ Fajdo -
Hi, it’s
Program.Mainboard.MassStorageMounted += Mainboard_MassStorageMounted;
you can get Access to the filesystem with
if (VolumeInfo.GetVolumes()[0].IsFormatted)
string rootDirectory =
VolumeInfo.GetVolumes()[0].RootDirectory;
string[] files = Directory.GetFiles(rootDirectory);
string[] folders = Directory.GetDirectories(rootDirectory);
Debug.Print("Files available on " + rootDirectory + ":");
for (int i = 0; i < files.Length; i++)
Debug.Print(files[i]);
Debug.Print("Folders available on " + rootDirectory + ":");
for (int i = 0; i < folders.Length; i++)
Debug.Print(folders[i]);
Debug.Print("Storage is not formatted. " +
"Format on PC with FAT32/FAT16 first!");
in Program.Started.
https://www.ghielectronics.com/community/forum/topic?id=16806
