SD Write Speed
Hello,
What is the max write speed for SD cards on the ChipworkX module?
I am using firmware version 4.1.4.0.
I tested the speed of the SD card using the following code.
private void someFunction()
string pathfile = "";
FileStream fStream = null;
LargeBuffer lb=new LargeBuffer(4000000);
pathfile=VolumeInfo.GetVolumes()[0].RootDirectory+"\\"+"Test.dat";
fStream=new FileStream(pathfile,FileMode.CreateNew);
fStream.Write(lb.Bytes,0,lb.Bytes.Length);
fStream.Close();
return;
Running this code I get 44kbytes per second.
Is there something I can do to increase the speed?
Please see this and follow the exact steps:
http://www.tinyclr.com/forum/1/1858/
