Today I did some test and the results are interesting.
Test equipments:
G120SOM, Sd speed is 30MHz, memeory clock is overdrived
Test file size: 1177027 bytes
File transfer is done using usb-cdc, data protocol is custom
Usb file transfer time is constantly 2.4sec so actual storage time is 2.4sec lesser than
measured time - program has special functionality to perform a “dumb” data copy and usb transfer speed is measured.
One file fragment size is 0xFFFE bytes
All time measurements are made in PC application - counter starts before first file fragment is sent and counter stops after “file saved” answer.
Used cards:
Class 4 Cards - 2Gb and 8Gb
Class 6 Card - 4Gb
Class 10 Card - 16Gb
Test results:
Test 1 - Pullup resistors 22Kohm
Clock speed is not measurable -trying this will cause sd card communication errors
Class 4 Cards
Usb transfer + file saving time ~62 sec, 2Gb card is sligthly faster
Class 6 card
Usb transfer + file saving time ~18 sec
Class 10 card
Can’t mount card
Test 2 - Pullup resistors 10Kohm
Class 4 Cards
Usb transfer + file saving time ~30 sec, 2Gb card is sligthly faster
Class 6 card
Usb transfer + file saving time ~12 sec
Class 10 card
Can’t mount card
Test 3 - Pullup resistors 5,6Kohm
Measured clock speed - 30MHz
Class 4 Cards
Usb transfer + file saving time ~25 sec, 2Gb card is sligthly faster
Class 6 card
Usb transfer + file saving time ~11 sec
Class 10 card
Can’t mount card
Test 4 - Pullup resistors 1.5Kohm
Class 4 Cards
Usb transfer + file saving time ~24 sec
Class 6 card
Usb transfer + file saving time ~10 sec
Class 10 card
Can’t mount card
Class 10 card is my android phone card, multiple partitions probably causes mount error. Tomorrow I will buy new class 10 card and will make some additional tests.
Why I tried changing pullup resistors - I have a long experience with PiC MCUs and there I found that pullups lower than 10Kohm gives better performance. Ok, sd card interface was SPI.
This test shows that pullup resistors may affect sd card writing speed, bigger difference was between 22kohm and 10Kohm. But this is only first test, maybe there is a some other problem that causes sd card communication speed issues…
What else, trying RLP, different boards? Or dump that question and say - netmf sdcard is slow…but usable.
