I am sorry, but I continue to have problems converting my application from 4.1 to 4.3. The code I had that worked for deleting a file on the SD Card no longer works. I have been unsuccessful in finding a solution. The error I am getting is as follows:
#### Exception System.InvalidOperationException - 0x00000000 (1) ####
#### Message: The card is already mounted.
#### Gadgeteer.Modules.GHIElectronics.SDCard::Mount [IP: 000c] ####
#### SDCardTest.Program::StartControl [IP: 004c] ####
#### Gadgeteer.Modules.GHIElectronics.Joystick::OnJoystickEvent [IP: 0057] ####
#### System.Reflection.MethodBase::Invoke [IP: 0000] ####
#### Gadgeteer.Program::DoOperation [IP: 001a] ####
#### Microsoft.SPOT.Dispatcher::PushFrameImpl [IP: 0054] ####
#### Microsoft.SPOT.Dispatcher::PushFrame [IP: 001a] ####
#### Microsoft.SPOT.Dispatcher::Run [IP: 0006] ####
#### Gadgeteer.Program::Run [IP: 001d] ####
A first chance exception of type ‘System.InvalidOperationException’ occurred in GTM.GHIElectronics.SDCard.dll
Error invoking method “Gadgeteer.Modules.GHIElectronics.Joystick” (check arguments to Program.BeginInvoke are correct)
The read and write sections of the code works however the File.Delete does not. The code is as follows:
using System.Text;
using System.ComponentModel;
using System.IO;
using System.IO.Ports;
using System.Collections;
using Microsoft.SPOT.IO;
using Microsoft.SPOT.Input;
using Microsoft.SPOT.Touch;
using Gadgeteer.Networking;
using GT = Gadgeteer;
namespace SDCardTest
public partial class Program
public static string ParameterFilepath = @ "\SD\ParameterFile.txt";
public string ResultsFilePath { get; set; }
public string CurrentParameters = "1,1,0,4,0,0,1";
public string[] StoredParameters = new string[7] { "1", "1", "0", "4", "0", "0", "1" };
public static int[] WriteParameters = new int[7];
bool SetParameters = false;
joystick.Calibrate();
joystick.JoystickPressed += new Joystick.JoystickEventHandler(joystick_JoystickPressed);
// SD Card
//Mount the SD card
//if (sdCard.IsCardMounted == false) sdCard.Mount(); Thread.Sleep(200);
//Get the root directory
GT.Timer timer = new GT.Timer(200);
timer.Start();
timer.Stop();
public void joystick_JoystickPressed(Joystick sender, Joystick.ButtonState state)
Debug.Print("joystick pressed");
StartControl();
public void StartControl()
if (sdCard.IsCardMounted == true)
if (File.Exists(ParameterFilepath) == true)
Debug.Print("File Exists");
// Set current parameters from default or from stored parameters
ReadTidisParameter(sdCard, CurrentParameters, out SetParameters);
File.Delete(ParameterFilepath);
sdCard.Unmount();
sdCard.Mount();
//Thread.Sleep(200);
Debug.Print("File Does Not Exist");
Debug.Print("Done Reading");
WriteTidisParameter();
Debug.Print("Done Writing");
public void ReadTidisParameter(SDCard sdCard, string CurrentParameters, out bool SetParameters)
try
FileStream sdcardreader = new FileStream(ParameterFilepath, FileMode.Open, FileAccess.Read);
byte[] data = new byte[100];
int read_count = sdcardreader.Read(data, 0, data.Length);
sdcardreader.Close();
CurrentParameters = new string(Encoding.UTF8.GetChars(data), 0, read_count);
Debug.Print(CurrentParameters);
catch
Debug.Print("FileStream Error");
SetParameters = true;
public void WriteTidisParameter()
sdCard.Mount();
bool fs_ready = false;
RemovableMedia.Insert += (a, b) =>
fs_ready = true;
while (!fs_ready)
System.Threading.Thread.Sleep(1);
string sdFilepath = ParameterFilepath;
Debug.Print(sdFilepath);
sdFilepath = rootDirectory + @ "\ParameterFile.txt";
FileStream sdcardstream = new FileStream(sdFilepath, FileMode.Create);
string sdfileline = CurrentParameters;
byte[] buffer = new byte[sdfileline.Length];
buffer = Encoding.UTF8.GetBytes(sdfileline + "\r\n");
sdcardstream.Write(buffer, 0, buffer.Length);
//Thread.Sleep(100);
sdcardstream.Close();
sdCard.Unmount();
I am also having problems with opening serial ports but I am still researching the problem.
