Example 3, uses a .netmf based solution to mount, read, and write some string data to the SD.
Using this example with a Spider module, I end up with a exception thrown right at the first line.
pStore = new PersistentStorage("SD");
Unhandled exception of type ‘System.InvalidOperationException’ has occurred in GHI.Premium.IO.dll.
Suggestions? I tested Example 1 successfully. There is a formatted 2gb card in the slot.
Thanks.
from the top of Program.cs
using System.IO;
using System.Text;
using GHI.Premium.IO;
using Microsoft.SPOT.Input;
using Microsoft.SPOT.IO;
using GT = Gadgeteer;
PersistentStorage pStore;
VolumeInfo pStoreI;
// Attempt to mount the FS and get info
pStore = new PersistentStorage("SD"); // crash!
pStore.MountFileSystem();
@ Familyghost - I just encountered this same problem after reformatting an SD card on Windows 8. The default Allocation Unit was 32 kilobytes. After I changed it to 4096 bytes, it worked.
@ jasdev - Thanks. I tried reformatting the card to FAT32 with 4096, but it did not affect the behavior. I went back to normal FAT format with default allocation selected.
I was able to validate the SD card will mount, read and write, using a different Gadgeteer test program that relied on this method:
this.sdCard = new GTM.GHIElectronics.SDCard(5);
sdCard.MountSDCard();
So the hardware is working.
But example #3 uses the GHI.Premium.IO Persistent Storage class.
And it crashes right on the first line where it creates the field.
@ Familyghost - I’m also using premium GHI (NETMF 4.1), and it crashed in that same place until I reformatted the drive with 4096 byte allocation units. Sorry, but I don’t know what else to suggest.
