SC20100 Graphics throws System.InvalidOperationException
The issue wasn’t memory, it is SPI problem that we will take a look. Weird to us that some board working fine.
Add them to the FILES section of the resources.
to all
i downloaded this tools
http://informatix.miloush.net/microframework/Downloads/Utilities/TinyFontTool/TinyFontToolGUI.zip
it create fonts with extension tinyfnt - after saving font rename saved extension from tinyfnt to tcfnt - after this you can use it with tinyclros without any issues .
Thanks for your advice. Changing the spi configuration mostly solved the issue.
However on my board I had to reduce the ClockFrequncy to 2_000_000 to achieve that justins example runs for a longer time.
Even with 2_000_000 the example occasionally stopped running after some minutes.
In this case I couldn’t catch an exception for the ‘st7355.DrawBuffer(data)’ command.
I will now try if it works ‘for ever’ with ClockFrequency 1_000_000
I must say that I used Justins example without the
if (mem < 2000)
GC.Collect();
GC.WaitForPendingFinalizers();
statement and the debugger gave this message before the App stopped
Failed allocation for 29 blocks, 464 bytes
So it seems that the fix @Justin posted is still needed
That is a different issue. Well, not an issue really but it is hard to explain. We are looking into improving in preview 3 for next week.
12Mhz should work fine in preview3, 1-2MHz is slow that effects to fps.
But still keep GC.WaitForPendingFinalizers() in your code. That is different story. :smiley:
I can confirm, preview3 works flawlessly with 12 Mhz
