SC20100 assembly mismatch
Hello All,
I have just started trying to implement some code with TinyCLR 2.
I have updated the firmware to preview 2 and am using the preview 2 nuget packages.
However I get the following error:
Found debugger!
Create TS.
Attaching deployed file.
Assembly: mscorlib (2.0.0.0) Attaching deployed file.
Assembly: GHIElectronics.TinyCLR.IO (2.0.0.0) Attaching deployed file.
Assembly: Tiny2Test (1.0.0.0) Attaching deployed file.
Assembly: GHIElectronics.TinyCLR.Devices.Uart (2.0.0.0) Attaching deployed file.
Assembly: GHIElectronics.TinyCLR.Native (2.0.0.0)
Error: the reference GHIElectronics.TinyCLR.Native cannot be used with this version of the firmware.
Firmware checksum 0xBBD3235C does not match the assembly checksum 0x0DF320E8.
Resolving.
Assembly: Tiny2Test (1.0.0.0) needs assembly ‘GHIElectronics.TinyCLR.Devices.Storage’ (2.0.0.0)
Assembly: Tiny2Test (1.0.0.0) needs assembly ‘GHIElectronics.TinyCLR.Devices.Gpio’ (2.0.0.0)
Assembly: Tiny2Test (1.0.0.0) needs assembly ‘GHIElectronics.TinyCLR.Devices.Uart’ (2.0.0.0)
Assembly: Tiny2Test (1.0.0.0) needs assembly ‘GHIElectronics.TinyCLR.Devices.Pwm’ (2.0.0.0)
Assembly: GHIElectronics.TinyCLR.Devices.Uart (2.0.0.0) needs assembly ‘GHIElectronics.TinyCLR.Native’ (2.0.0.0)
Error: a3000000
Waiting for debug commands…
The program ‘[5] TinyCLR application: Managed’ has exited with code 0 (0x0).
Any Ideas?
Rob
Also I have tried with both
v2.0.0.21000-preview2
2.0.0.20000-preview2
Did you run the TinyCLR 2.0 Visual Studio Project System, VSIX file too?
http://new-docs.ghielectronics.com/software/tinyclr/downloads.html
Yes, it seemed to update it
Also Firmware below as
also some libraries
Hello,
I cleared the firmware a few times a reloaded it.
that seemed to fix it.
cheers
Rob
