I had a similar post 6 months back, but then had to put that part of the project aside until now. So I thought I should start a new thread.
I am trying to capture an image from a Serial Camera L2 and save it to SD card for processing on a PC.
I can capture the image, convert it to a file and save it. It appears on the SD card and has some content. However when I try to load the file on the PC it says it is corrupted.
I am using the workaround ConvertToFile published long ago on the forum as Bitmaps.ConvertToFile still seems broken.
Running on a Cobra2 with version 4.3.6.
The following is my test program:
using Microsoft.SPOT.IO;
using System.IO;
using GTM = Gadgeteer.Modules.GHIElectronics;
using GT = Gadgeteer;
using GHI.Utilities;
namespace CameraTest
public partial class Program
private GT.Timer timer;
Microsoft.SPOT.Bitmap image = null;
this.camera.ImageResolution = GTM.SerialCameraL2.Resolution.QQVGA;
this.camera.StartStreaming();
this.timer = new GT.Timer(1);
timer.Behavior = GT.Timer.BehaviorType.RunOnce;
this.timer.Tick += this.timer_Tick;
System.Threading.Thread t = new System.Threading.Thread(cameraThread);
t.Start();
private void cameraThread()
while(true)
while (!camera.NewImageReady) Thread.Sleep(10);
if (image != null) image.Dispose();
image = camera.GetImage();
camera.StopStreaming();
timer.Start();
Thread.Sleep(2); //Lets timer run so I can see image
VolumeInfo[] vi2 = VolumeInfo.GetVolumes();
if (vi2[0].IsFormatted)
try
int fileSize = image.Height * image.Width * 3 + 54;
LargeBuffer data = new LargeBuffer(fileSize);
ConvertToFile(image, data.Bytes);
string imageName = rootDirectory + @ "\Test_" + DateTime.Now.Ticks.ToString() + ".bmp";
FileStream FileHandle = new FileStream(imageName, FileMode.Create);
FileHandle.Write(data.Bytes, 0, fileSize);
FileHandle.Close();
VolumeInfo[] vi = VolumeInfo.GetVolumes();
for (int i = 0; i < vi.Length; i++) vi[i].FlushAll();
catch (Exception exp)
Debug.Print(exp.Message.ToString());
Debug.Print("Storage is not formatted. " + "Format on PC with FAT32/FAT16 first!");
System.Threading.Thread.Sleep(30000);
private void timer_Tick(GT.Timer timer)
this.displayTE35.SimpleGraphics.DisplayImage(image, 0, 0); //will not run anywhere but in a timer routine
private void ConvertToFile(Bitmap bitmap, byte[] outputBuffer) //From old post since Bitmaps.ConvertToFile still seems broken
var inputBuffer = bitmap.GetBitmap();
var width = (uint)bitmap.Width;
var height = (uint)bitmap.Height;
if (outputBuffer.Length != width * height * 3 + 54) throw new System.ArgumentException("outputBuffer.Length must be width * height * 3 + 54.", "outputSize");
System.Array.Clear(outputBuffer, 0, outputBuffer.Length);
Utility.InsertValueIntoArray(outputBuffer, 0, 2, 1977);
Utility.InsertValueIntoArray(outputBuffer, 2, 4, width * height * 3 + 54);
Utility.InsertValueIntoArray(outputBuffer, 10, 4, 54);
Utility.InsertValueIntoArray(outputBuffer, 14, 4, 40);
Utility.InsertValueIntoArray(outputBuffer, 18, 4, width);
Utility.InsertValueIntoArray(outputBuffer, 22, 4, (uint)(-height));
Utility.InsertValueIntoArray(outputBuffer, 26, 2, 1);
Utility.InsertValueIntoArray(outputBuffer, 28, 2, 24);
for (int i = 0, j = 54; i < width * height * 4; i += 4, j += 3)
outputBuffer[j + 0] = inputBuffer[i + 2];
outputBuffer[j + 1] = inputBuffer[i + 1];
outputBuffer[j + 2] = inputBuffer[i + 0];
