Using the ARM GCC Cross Compiler in Visual Studio (Vers. 15.5.0 Prview 2.0), working with Mbed and C++ got more comfortable.
Using an ST-Link adapter and the STM32 ST-LINK Utility makes deploying quite easy
Here is a simple example for the BrainPad using LEDs, Button, Buzzer, Display, Light/Temperatur Sensors and Accelerometer.
The following Mbed libraries are used:
Adafruit_GFX by Neal Horman -Adafruit_GFX - A derived version of the BSD licensed Adafrut GFX… | Mbed
MMA8453 by Givanni Bruno -MMA8453 - Accelerometer library (simple) | Mbed
beep by Peter Drescher -beep - Make noise with a piezo buzzer. Use a pwm pin. | Mbed
In the VS Project folder CppProperties.json must be:
"configurations": [
"inheritEnvironments": [
"gcc_arm"
"name": "gccarm",
"includePath": [
"${env.INCLUDE}"
"defines": [
"DEVICE_I2C",
"DEVICE_SERIAL",
"DEVICE_ANALOGIN",
Here is the Example Code for the Brain:
#include "mbed.h"
#include "Adafruit_GFX/Adafruit_GFX.h"
#include "Adafruit_GFX/Adafruit_GFX_Config.h"
#include "Adafruit_GFX/Adafruit_SSD1306.h"
#include "MMA8453/MMA8453.h"
#include "beep/beep.h"
#define SSD1306_I2C_ADDR (0x78) // SSD1306 I2C Address
DigitalOut myBlueLed(PC_6, 0);
DigitalOut myRedLed(PC_9, 0);
DigitalOut myGreenLed(PC_8, 0);
DigitalIn u_Button(PA_5, PullUp);
AnalogIn LightSensor(PB_1);
AnalogIn TempSensor(PB_0);
Serial pc(SERIAL_TX, SERIAL_RX);
I2C gI2C(PB_7, PB_6);
MMA8453 accel(PB_7, PB_6);
Adafruit_SSD1306_I2c gOled(gI2C, PC_8, SSD1306_I2C_ADDR, 64, 128);
Beep myBuzzer(PB_8);
int main()
myGreenLed = 0;
wait(4.0);
gOled.clearDisplay();
gOled.setTextCursor(0, 0);
gOled.printf("Hallo BrainPad\r\nU-Button beeps");
gOled.display();
myBuzzer.beep(440.0, 0.5);
wait(4.0);
while (1) {
gOled.printf("X: %f\r\n", (accel.getX() * 100));
gOled.printf("Y: %f\r\n", (accel.getY() * 100));
gOled.printf("Z: %f\r\n\r\n", (accel.getZ() * 100));
uint32_t reading = LightSensor.read_u16();
// some arbitrary calculations
float lightLevel = (reading - 2000) / (float)700;
gOled.printf("L: %.2f\r\n", lightLevel);
reading = TempSensor.read_u16();
// The scaling is probably not correct
float tempLevel = (reading - 2000) / (float)700 ;
gOled.printf("T: %.2f\r\n", tempLevel);
gOled.display();
if (u_Button.read() == 0) {
myRedLed = 0;
myBlueLed = !myBlueLed;
else {
myBlueLed = 0;
myRedLed = !myRedLed;
wait(2.0);
