Hello all, is there a way to synchronize the RTC while programming our boards? I mean, I do not use NTP in my system, I am using GPS to synchronized the RTC in field. But in some cases, customers do not have correct GPS data (Bad NMEA multiplexer configuration) and when we investigate potential problems on the data logged on the SD card, data are not properly time stamped. It could help to have a factory RTC synchronization.
Is there a way to retrieve from VS the date time of the HOST computer to fill the RTC while programming?
