Hi guys, I have a FEZ Hydra and I want to sample GPIO inputs every 100 microseconds, which is too fast for .NET and I need to use RLPLite and native code. Since I want to sample at 100 microseconds, I try to use Timer2 on FEZ Hydra, below is the code to do the timer initialization. The timer works fine and I can see the right waveform on the oscilliscope, however if I enable the interrupt handler by setting AT91C_BASE_AIC->AIC_IECR = 0x1 << AT91C_ID_TC2; the software hangs and I have to reflash the firmware. Any one has any idea how to handle interrupts of any sort in native code? Much appreciated.
void timer0_c_irq_handler(void)
//* Acknowledge interrupt status
dummy = AT91C_BASE_TC0->TC_SR;
test++;
// AT91C_BASE_AIC->AIC_ICCR = (0x1 << AT91C_ID_TC0);
int init_timer(void *voidArray, int* intArray, unsigned char* byteArray)
test = 1;
AT91C_BASE_PIOD->PIO_PDR = AT91C_PD10_TIOA2;
AT91C_BASE_PIOD->PIO_OER = AT91C_PD10_TIOA2;
AT91C_BASE_PIOD->PIO_BSR = AT91C_PD10_TIOA2;
// if(AT91C_BASE_TC2->TC_SR & AT91C_TC_CLKSTA){
// return 0; //somebody already enabled it, perhaps the .NET framework
AT91C_BASE_PMC->PMC_PCER = ((unsigned int) 1 << AT91C_ID_TC2);
//setup timer
AT91C_BASE_TC2->TC_CCR = AT91C_TC_CLKDIS ;
AT91C_BASE_TC2->TC_IDR = 0xFFFFFFFF; //disable interrupt
dummy = AT91C_BASE_TC2->TC_SR; //Clear status bit
AT91C_BASE_TC2->TC_RA = 3750;
AT91C_BASE_TC2->TC_RB = 4100;
AT91C_BASE_TC2->TC_RC = 5000; //every 100 us
AT91C_BASE_TC2->TC_CMR = AT91C_TC_CLKS_TIMER_DIV1_CLOCK |
AT91C_TC_BURST_NONE|
AT91C_TC_ETRGEDG_NONE|
AT91C_TC_EEVTEDG_NONE|
AT91C_TC_EEVT_XC0 |
AT91C_TC_WAVESEL_UP_AUTO|
AT91C_TC_WAVE|
AT91C_TC_ACPA_SET |
AT91C_TC_ACPC_CLEAR |
AT91C_TC_EEVT_XC0
; //use TIMER_CLOCK1 @ 100 MHz, WAVE mode, WAVE mode with trigger on RC compare, bits set: 15,14,10
AT91C_BASE_TC2->TC_IER = AT91C_TC_CPCS | AT91C_TC_CPAS; //enable RA, RB, RC interrupt on compare match
//set interrupt handler
AT91C_BASE_AIC->AIC_IDCR = 0x1 << AT91C_ID_TC2;//Disable the interrupt on the interrupt controller
AT91C_BASE_AIC->AIC_SVR[AT91C_ID_TC2] = (unsigned int) timer0_c_irq_handler ;
AT91C_BASE_AIC->AIC_SMR[AT91C_ID_TC2] = AT91C_AIC_SRCTYPE_INT_EDGE_TRIGGERED | 0x4; //Positive edge triggered, priority 4
AT91C_BASE_AIC->AIC_ICCR = 0x1 << AT91C_ID_TC2 ;//clear pending interrupt
AT91C_BASE_AIC->AIC_IECR = 0x1 << AT91C_ID_TC2 ;//Enable interrupt handler
AT91C_BASE_TC2->TC_CCR = AT91C_TC_CLKEN; //Enable the clock
AT91C_BASE_TC2->TC_CCR = AT91C_TC_SWTRG; //Start the clock
return 1;
