Hi there,
I was wondering, if RLP would also work on the Gadgeteer Modul. I tried it, but I got an exception when
RLP.LoadELF(elf_file); was called.
Thanks for your answer.
Tobias
Hi there,
Tobias
it should work. did you unlock your device?
Right, that might be the problem, I knew there was something …
… could you point me the direction how to unlock?
try doing a search for “RLP unlock”
Ok found it. For those that still search click http://www.ghielectronics.com/account/rlp/
to request a key.
THX.
Did you compile it with the correct designation address?
I see you are bringing the old project back. You know we had mpeg playing before right? It is sad that we lost the video showing it! http://wiki.tinyclr.com/index.php?title=RLP_Video_Playback
This is a way-too-old-example to use. I was going to get to it one day and clean it up but maybe you and community can make ti happen sooner.
This is very complex project. Please start with something simpler to understand RLP
