Got a sweet 32 light strip of 3 color LEDs from Sparkfun [url]http://www.sparkfun.com/products/10312[/url] . A sample sketch was provided for an arduino, which ran with (literally) a blindingly fast refresh rate (duino pro, 5v, 16mhtz). I ported the code to NETMF, ran it on a Domino, and discovered the refresh rate of the strip slowed down considerably. This is some straight up bit banging, and I’m wondering if it is better done in RLP?
namespace RgbStrip
const int LEN = 32; // 32 LEDs on this strip.
const bool HIGH = true; // I like using HIGH/LOW
const bool LOW = false; // for bit bangin' like this.
static long[] strip; // strip color data array
static OutputPort sdi; // digital pin 2
static OutputPort cki; // digital pin 3
strip_colors = new long[LEN];
sdi = new OutputPort((Cpu.Pin)FEZ_Pin.Digital.Di2, LOW);
cki = new OutputPort((Cpu.Pin)FEZ_Pin.Digital.Di3, LOW);
// spit out some bytes
loop();
// Push out increasingly bright primary colors
private static void loop()
// Saturation must be byte sized, 0-255.
// Outside this range, strange things happen...
int lHue = 120; // low sat value
int hHue = 160; // high sat value
while(true)
for (int i = lHue; i < hHue; i++)
addColor(i, 0, 0);
addColor(0, i, 0);
addColor(0, 0, i);
// Add one color to the strip
private static void addColor (int R, int G, int B)
// shift all existing colors
for (int x = (LEN - 1); x > 0; x--)
strip[x] = strip[x - 1];
// create a new RGB color
long new_color = R; // red
new_color <<= 8; // byte shift
new_color |= G; // green
new_color <<= 8; // shift again
new_color |= B; // blue
strip[0] = new_color; // add to strip
postFrame(); // push data
// Pushes out current strip color array.
// Each LED requires 24 bits of data.
// Once the bits have been delivered,
// the IC immediately relays these bits to its neighbor.
// Pulling the clock low for 500us or more causes the
// IC to post the data.
private static void postFrame ()
for(int i=0;i<LEN;i++)
for(byte bit = 23 ; bit != 255 ; bit--)
cki.Write(LOW); // only change data when clock is low
long mask = 1 << bit;
if ((strip[i] & mask) > 0)
sdi.Write(HIGH);
sdi.Write(LOW);
cki.Write(HIGH); // data is latched when clock goes high
cki.Write(LOW); // pull clock low to put strip into reset/post mode
//Thread.Sleep(1); // required delay. Note, this was not needed here (slow enough already).
