yes I received unlock code and it works correctly, RLP is enabled, like explained in “GHI Electronics NETMF Library”, but it doesn’t work.
The examples now work, but my elf file not. I have tried to re-compile it, but it is the same.
I don’t understand where the problem is.
Thank to all!
I see in the system that you just got your RLP access so this is a good start.
Now, maybe your ELF is too big or at a wrong memory location…start with provided examples and make sure it works as is then gradually make changes to see where the problem is.
