Hello, I am having some problems with an RLP call that I am making causing the board (FEZCobraIII) to crash. Stepping through the app, it just hangs and then stops when the RLP function is called. I can no longer talk to the board, and to recover I have to go through a “Loader (TinyBooter) Update” process from FEZConfig.
I have isolated the failing code and made a working version. The only difference is that it fails when I try to pass in a byte[] array (of length 512). The native code that works and doesn’t work is below. Any tricks I am missing in passing an array? I am calling it synchronously so the data should not be moved by the CLR.
NOT WORKING:
typedef unsigned char byte;
Sets the RGB data for an entire matrix
void PushRgbMatrix(void** args)
byte* rowData = (byte*)(args[1]);
int row,col;
byte pinStates;
for(row=0; row<16; row++)
RLP->GPIO.Writepin(_pRow[0], (row & 0x01));
RLP->GPIO.Writepin(_pRow[1], (row & 0x02) >> 1);
RLP->GPIO.Writepin(_pRow[2], (row & 0x04) >> 2);
RLP->GPIO.Writepin(_pRow[3], (row & (4+4)) >> 3); //don't comment on this--the forum formatter didn't like the hex eight
RLP->GPIO.Writepin(_pOE, 0);
for(col=0; col<32; col++)
pinStates = rowData[(row * 32) + col];
RLP->GPIO.Writepin(_pRgb1[0], (pinStates & 0x01)); //R1
RLP->GPIO.Writepin(_pRgb1[1], (pinStates & 0x02) >> 1); //G1
RLP->GPIO.Writepin(_pRgb1[2], (pinStates & 0x04) >> 2); //B1
RLP->GPIO.Writepin(_pRgb2[0], (pinStates & 0x08) >> 3); //R2
RLP->GPIO.Writepin(_pRgb2[1], (pinStates & 0x10) >> 4); //G2
RLP->GPIO.Writepin(_pRgb2[2], (pinStates & 0x20) >> 5); //B2
RLP->GPIO.Writepin(_pClock, 1);
RLP->GPIO.Writepin(_pClock, 0);
RLP->GPIO.Writepin(_pLatch, 1);
RLP->GPIO.Writepin(_pLatch, 0);
C# calling code
_driver.PushRgbMatrix(_canvas.Buffer);
//Where _canvas.Buffer is a property returning a byte[] of size 512.
WORKING:
void SetTestMatrixNoParameters(void** args)
int row,col;
byte pinStates;
byte rowData[512];
int i;
for(i=0; i<512; i++)
rowData[i] = 0x31; //some color pair
RLP->GPIO.Writepin(_pOE, 1);
