I just got the Rhino and have it working with the Rhino Demo Solution.
I am updating the display just fine.
But, it gives an error when trying to do the
Dhcp.EnableDhcp(mac);
call.
I plugged it into a linksys router and right into my brighthouse cable modem. Neither one worked.
I download GHI NETMF 4.1.5.1 from website but still fails.
byte[] mac = { 43, 185, 44, 2, 206, 120 };
WIZnet_W5100.Enable(SPI.SPI_module.SPI1, (Cpu.Pin)FEZ_Pin.Digital.IO38, (Cpu.Pin)FEZ_Pin.Digital.IO67, true); // WIZnet interface on FEZ Connect
which returns fine.
when Dhcp.EnableDhcp(mac) is called, it gives the error i showed previously.
Its a brighthouse cable modem that I use to get to internet so the DHCP should be fine.
I tried a different mac address just to see if it made a difference and it did not work either.
Jim
Do you have a sample sln file for rhino with static ip that you know works?
Then I could just see if it runs.
Also, do you know when I can get a sln for rhino for SD.
When I try to add :
to my project as a reference my debugger stops working. Darndest thing!
even though i just got this unit today, maybe i need to reflash it to the very latest.
Jim
ok, i will reburn it all tomorrow.
How do i get to the buttons on the rhino to reboot/flash etc? do i have to take screws out and open case?
is there a diagram that shows it all?
Thanks for all your help!
Jim
…but lets not forget the fact that there are mixed firmware and SDK versions at play.
It is critically important that these are in sync. Check the release notes file (c:\program files\GHI Electronics\GHI NETMF v4.1 SDK\Release Notes.rtf) to verify the firmware version you should have. Then check the board has that firmware version. Then make sure you either remove all references to GHI components and re-add them, or start a new project and add code to that.
