I have a pin that I set as an PWM output. I however want to use it later as a normal OutputPort. How do I release the pin for reuse?
Gadgeteer or normal NetMF?
Disposing of the managed object that uses the pin usually releases it.
NETMF EMX Module
With Gadgeteer you can’t release a pin.
With NETMF you just call the Dispose method of the PWM object, as Architect said.
I will try it quickly and reply with outcome.
