It’s not explicitely described in the EMX documentation, so maybe you can help.
I need to have a fine control of the power delivered by leds. I control the leds using a PWM signal sent to the led drivers. Today I only have 8 bits PWM resolution with the board I currently use. I can grade the PWM between 0 (OFF) and 255 (Full Power)
Can you tell me what is the resolution of the PWM channels of the EMX Module ? Can I have 10bits or 12bits resolution for the PWM gradation ?
Thanks for the answer. So, if the cycle is coded in nano seconds, it means that for a 400Hz cycle, which is 2.5ms, I have 2,500,000 steps to code the PWM value, right ?
I have another question : i saw that the PWM outputs are linked. Are they linked only for the frequency, or for both the frequency and the High Time value ? In other words, PWM 0 and 2 are linked. Can i set both pwm with the same period of 2.5 ms, then set High value of PWM 0 to 1ms and High value of PWM 2 to 0.5 ms, to have different output signals ?
