I’m new at c# and the FEZ modules.
Now i am working on a project that reads out a string from a GPS. (NMEA-string)
The whole program is working, but when i want to ad a ‘.Replace’ command he gives
next error:
[quote]‘string’ does not contain a difinition for ‘Replace’ and no extension method ‘Replace’ accepting
a first argument of type ‘string’ could be found (are you missing a using directive or an assembly
reference?)[/quote]
Well, it means your using an extension method that does not exist in NETMF. There are lots of other string operators so you can accomplish what your after with a bit more code. Also look over on Fezzer, i.e. the ‘Code’ link at the top of the screen as you may find someone has added an extension method for Replace.
