What kind of relay is used with the FEZ component?
It should trigger at 3V but couldn’t find one. If there would be a distributor near I would by it.
Roel
Roel
Call the closest distributor to your location and ask them to order what you need.
You need a transistor and protection diode to use relays. Just adding a relay is not enough.
This is the relay being used in the component:
[url]http://www.alldatasheet.com/datasheet-pdf/pdf/333594/OMRON/G5LA-14.html[/url]
