Hi guys! I want to control the 220v circuit using Relay X1 module and Cerbuino bee. I want to turn on/off the bulb. I need help. how to correctly connect the circuit? Relay has Normally Open, Common, and Normally Closed terminals, bulb connected to the wall socket 220v. What should i do to control the bulb?
@ Alex Bilityuk - If I were you, I would try to avoid doing that. It is easy, but so many things can go wrong when you don’t have enough knowledge.
Thank you iamin, that is what i am looking for. I understand the high voltage is dangerous and will be very attentive.
@ Alex Bilityuk -
I have done this and is FAR SAFER…
Get something like this:
Not pushing any brand … Just a general link of what I am talking about.
http://www.amazon.com/s?ie=UTF8&page=1&rh=i%3Aaps%2Ck%3Aremote%20220%20volt%20switch
Then just hack the Remote.
