Today I encountered an interesting failure during app deployment reboot (image attached).
I was able to get back to work (yeh; work - that’s a good one! :P) by hitting my reset button.
BTW; for those who aren’t solder-worthy, a small header that could accommodate an external reset switch would be a friendly thing to add to teh mainboards…
Interesting enclosure. What is it?
As for the error. First time I see it.
This shouldn’t happen. You will probably not see it in future. Make sure you have a reliable power source.
I will let you in on a secret. Connect the button to Z socket and it becomes a reset button
@ Architect - it’s just a $10 project enclosure from my local electronics house (Vetco in Bellevue, WA). I added the hinges and latch. I’ll be posting my efforts soonish (still working out the kinks in the WiFi scanner app)
@ Gus
- power; I’m running on a powered hub, since I have noticed “intermittent” behavior when running directly from a USB port.
- Z socket; apparently, I can read the schematic to answer other folks’ needs but not for my own use…
Thanx!
