I have a Domino, and I am looking to put in a real time clock, using it’s own battery power.
Any suggestions?
Also if someone has done this, do you have a code sample of how you implemented?
Any suggestions?
The Domino has a build-in RTC, you just have to connect a 3.3V coin cell and set the time.
DateTime dt = new DateTime(your date here);
RealTimeClock.SetTime(dt);
Utility.SetLocalTime(RealTimeClock.GetTime());
This all is described on page 103 of the Beginners Guide to NETMF [url]http://www.tinyclr.com/downloads/Beginners%20guide%20to%20NETMF.pdf[/url]
Eric
Thx. I missed that, since I am focussing on a particular application conversion from PC to Micro Framework.
This is the only thread that I have seen yet that comes close to my question, I have built a clock. I have it working fine, connected up to my LCD and it looks grand. But I am looking for a way for the Domino to get time from an outside source, preferably my PC. I would also like for it to get the information the same way it normally gets it, through the USB port.
Is there a way to get this information from my PC, or barring that, any other outside source?
If you have it connected to your network you could pull it from a time server or the net.
You can write a pc program to get
Domino all info it need. And it will do that using USB
Hey Gus, can you point me in a direction so I can learn how to do this? I have never programmed for USB and any useful finger pointing would be appreciated.
Take a look at USB_CDC class
Adding to what Architect said, If you can use it using a serial port then you can use it using USB. We did all the hard work so it is easy for you.
This is a good tutorial for someone to make I guess. Maybe I should make it
Well FezTerm might be all you really need in a project - although it’s intent is to give you debugging as well, but that’s somewhat unnecessary in your case since you know it’s working.
http://www.microframeworkprojects.com/index.php?title=FezTerm
