All,
I’m trying to read a file that is roughly 4MB in size into an byte[] array with the G120. I know the G120 has 13MB of sram, so I should have no problems there?
Here is my code, i’m using .netmf 4.2 (since that’s what Tinkr is built for)
PersistentStorage sdCard = new PersistentStorage("SD");
sdCard.MountFileSystem();
FileStream fs = new FileStream(rootDirectory+"\\test.bin", FileMode.Open);
long fileSize = fs.Length;
byte[] data = new byte[fileSize];
int readCount = fs.Read(data, 0, data.Length);
sdCard.UnmountFileSystem();
It blows up when it tries to create the byte array to specified length.
GC: performing heap compaction...
#### Exception System.OutOfMemoryException - CLR_E_OUT_OF_MEMORY (1) ####
#### Message:
#### GHI_SDCardTesting.Program::Main [IP: 007a] ####
A first chance exception of type 'System.OutOfMemoryException' occurred in GHI_SDCardTesting.exe
How should I handle wanting to work with data this big?
Thanks in advance!
@ Dat - Thanks for the reply, unfortunately that did not work
Here is the code modified
FileStream fs = new FileStream(rootDirectory+"\\tune.bin", FileMode.Open);
Stopwatch sw = Stopwatch.StartNew();
using (LargeBuffer lb = new LargeBuffer((int)fileSize))
int readCount = fs.Read(lb.Bytes, 0, lb.Bytes.Length);
sw.Stop();
Debugger.Break();
The array in the LargeBuffer object returns 0x00’s for the entire size.
Is that the proper way to utilize it? Also, that bit of code took 13~ seconds to run, (even though it got no result). Can anything be done to speed it up?
Thanks again
@ zeroaviation -
[quote]The array in the LargeBuffer object returns 0x00’s for the entire size.
[/quote]
That because fileSize was zero, not LargeBuffer
Thanks for the reply Dat. I figured it out, ended up with two files on the SD card that were not correct.
Anything that can be done to speed up the read time? 13 seconds is pretty lengthy for only 4mb (I know embedded and .netmf is slow…)
Thanks again!
