I have a 5" LCD I am working on and because the ChipworkX module I have is configured for 4.3" with 480x272 display, I need to change the timing via code and do a reboot.
I am trying to see if I can do this as part of the main system software so that once a board is programmed with the software, it checks to see if set to the correct screen resolution and if not, makes and the changes and does a reboot. After this the main application runs.
I am trying to avoid having to install a configuration app and then the main app after this.
I already have the following to set the LCD parameters.
lcdConfig.Width = 800;
lcdConfig.Height = 480;
lcdConfig.PriorityEnable = false;
lcdConfig.OutputEnableIsFixed = false;
lcdConfig.OutputEnablePolarity = true;
lcdConfig.HorizontalSyncPolarity = true;
lcdConfig.VerticalSyncPolarity = true;
lcdConfig.PixelPolarity = false;
lcdConfig.HorizontalSyncPulseWidth = 1;
lcdConfig.HorizontalBackPorch = 92;
lcdConfig.HorizontalFrontPorch = 16;
lcdConfig.VerticalSyncPulseWidth = 4;
lcdConfig.VerticalBackPorch = 26;
lcdConfig.VerticalFrontPorch = 7;
lcdConfig.PixelClockDivider = 2;
Is there some way during startup I can read the current LCD settings?
