@ Dave McLaughlin -
Fully Yes, D0 and D1 are TTL 0/5V compliant. Interal PullUp is also often provided by the Reader so that an InterrputPort with EdgeLow trigger is sufficient !
Advantage of this against RS232 is that you have plenty of Inputs on a chip, where you do not have so many RS and often you need RS to be used for dialing instead of just reading datas from a “passive” peripheral…
I think, it would be nice to have code sample for the less experienced.
@ julien.pierre -
In pseudo language, I would say :
Define a STRING Wiegand_Code as default EMPTY;
Define a INTERRUPTPORT D0 as default HIGH;
Define a INTERRUPTPORT D1 as default HIGH;
Define an EVENT D0_Evt as EDGELOW;
Define an EVENT D1_Evt as EDGELOW;
Define an INT Code_Length as default 26;
CODE :
D0_Evt_ONINTERRUPT
ADDCHAR(‘0’) TO Wiegand_Code;
IF (LEN(Wiegand_Code) == Code_Length)
Print WIegand_Code;
Wiegand_Code = EMPTY;
D1_Evt_ONINTERRUPT
ADDCHAR(‘1’) TO Wiegand_Code;
Print WIegand_Code;
Very schematic I recognize but it will work !
