One question do you have mounted storage?
Something like this:
class FlashCard
public byte[] picData;
public PersistentStorage sd_card;
In FlashCard class:
private static void MountStorage(string storage)
try
sd_card = new PersistentStorage(storage);
sd_card.MountFileSystem();
// Format the media if it was not.
VolumeInfo sdvolumeinfo = new VolumeInfo(storage);
if (!sdvolumeinfo.IsFormatted)
sdvolumeinfo.Format("FAT", 32, true);
catch (Exception)
public void ShowPic()
FlashCard flash = new FlashCard();
flash.MountStorage("SD");
flash.testSD();
Bitmap img = new Bitmap(flash.picData , Bitmap.BitmapImageType.Bmp);
LCDPanel.Clear();
LCDPanel.DrawImage(0, 0,img, 0, 0, 272, 480);
LCDPanel.Flush();
If this will work for you then you need move MountStorage() method to your main class and call it on device start only once and not in each ShowPic() request …
The following crash: First code is snippet from the main, class Programm
sdCard.testSD(); //read file from sd card to picdata
Thread.Sleep(1000);
lcd.ShowPic(); //show picdata on screen
Class Display:
LCDPanel.Clear();
LCDPanel.Flush();
The above code will crash ath the bitmap img line, but when I in the class Programm remove the line sdCard.testSD(); and do the following in the class Display
flash.testSD(); //read bitmap from sd card and put in picData
LCDPanel.Clear();
LCDPanel.Flush();
