Hi
I’ve recently bought a Raptor and am now trying to get to grips with C#. I’ve been slowly working my way through the tutorials and things are starting to become a little clearer - until tonight.
I appear to have a problem with the RTC where the time isn’t being set correctly. I’m using the RealTimeClock Example 2 tutorial but the output from the debugger is as follows:
Using mainboard GHI Electronics FEZRaptor version 1.0
Current Real-time Clock 01/01/1977 01:01:01
Time is not resonable
New Real-time Clock 01/01/1977 01:01:01
TinyBooter Version is 4.2.11.2
TinyCLR Version is 4.2.11.2
I’ve managed to isolate the problem to the Flash Module. If I unplug the flash module the RTC can be set correctly - with it plugged in to any of the ‘S’ sockets the RTC cannot be set.
I was sure it was something I had done initially but if I disconnect the Flash module the code works fine.
using System.Collections;
using Microsoft.SPOT.Touch;
using Gadgeteer.Networking;
using GT = Gadgeteer;
using GHI.Premium.Hardware;
namespace RTCTest
public partial class Program
timer.Tick +=<tab><tab>
timer.Start();
DateTime DT;
try
DT = RealTimeClock.GetTime();
Debug.Print("Current Real-time Clock " + DT.ToString());
catch // If the time is not good due to powerloss or being a new system an exception will be thrown and a new time will need to be set
Debug.Print("The date was bad and caused a bad time");
DT = new DateTime(2012, 1, 1, 1, 1, 1); // This will set a time for the Real-time Clock clock to 1:01:01 on 1/1/2012
RealTimeClock.SetTime(DT); //This will set the hardware Real-time Clock to what is in DT
if (DT.Year < 2014)
Debug.Print("Time is not resonable");
Debug.Print("Current Real-time Clock " + RealTimeClock.GetTime().ToString());
DT = new DateTime(2014, 2, 16, 7, 30, 0); // This will set the clock to 9:30:00 on 9/15/2011
Debug.Print("New Real-time Clock " + RealTimeClock.GetTime().ToString());
@ Sprigo - I would like for you to try an experiment. With the flash module attached, can you change the date that is used in the program to a date that is not on a Sunday? But before changing the date can you erase the deployed application first then re deploy with a date that is not Sunday?
I changed the date to the 19th Feb 2014 and it works correctly. I then changed back to the 16th Feb and it’s back to 1/1/1977 It’s the same for the 23rd Feb 2014, another Sunday.
@ Sprigo - It was a bug that we just discovered. The main processor uses 1~7 as the day codes while NetMF uses 0~6 as the day code and if 0 is used on the chip, the calendar does not get set correctly and the RTC does not function as supposed to. This is going in know issues, however, we have fixed it but we are waiting on how we will release this fix. If you get the datasheet, there may be a way you can manually set the RTC in the mean time.
